Every night a transponder of "Data" is activated-11024 V,365,3/4, but in fact it has media content,because stream uses codecs and appears to be a stream radio IP? I tried all the codecs that I have installed on my pc,but I have not managed to work out what is transmitted.If someone wants to try,I shall provide a file recorded.
07.0°E Eutelsat 7B (OLD POSITION DX>Ku)
Hi satesco,
can you please upload the original TS capturing?
Hi newsy,
You've got here more than one file from 7.0V-11025 V.I hope you will be able to find out what is this stream. I also tried several players but none was useful.
I have to say that I found many transponders that have such streams.If you're interested,I could send them to you.For now I want to see what you've discovered at 11024 V.
Thanks in advance
satesco: After a deep scan on 11025V , nothing else found than DATA.
anyone else for another point of view ?
This is an EBU TP , this might be a daily DATA TX ?
11206 V,2000,3/4 and 11217 V,2000,2/3
Not sure, but I think these are transponders on Africa spot.Could someone check them?Thanks -
Great, who knows!
I see them too but 2.7 dB is not good enough for lock. -
Hi hvdh,
Before all,Happy New Year 2016 :),and thanks for trying.Maybe Feedsat will manages to lock them
No problem, the answer at this page:
/edit by qwer: LINKS disappeared (01.08.2020).
- ID: Digiturk_UHD
- Freq: 10761.263
- Pol: Horizontal
- SR: 29992.985
- Mod: QPSK2
- FEC: 5/6
- Std: DVB-S2
- 3840 x 2160 pixels ! -
Thanks Noelsat!
Put your post in this toppc here DX>Ku.
Best Regards
qwer. -
11150 V 13775 3/4
ARTE HD / SD -
Not sure, but I think these are transponders on Africa spot.Could someone check them?ThanksTwo data frequencies.(multi+continous str.)
Scan Europe beam B.
Hi newsy,You've got here more than one file from 7.0V-11025 V.I hope you will be able to find out what is this stream. I also tried several players but none was useful.
Thanks in advance
To find out what it is (apparently no video stream) we could replay it to virtual ethernet adapter and capture a wireshark trace..
12676 H,6427,2/3,Dvb-S2/8PSK-(Empty)
Started a new channel-Yek(test?) on transponder listed on FlySat as test carrier by Enosat.
11345 H,27500,5/6,Dvb-S/QPSK-Channel Yek -
7B-Europe B beam scan.
11345 H,27500=channel yak
stopped program -
Some situations tonight from my place. 4.2Mt.
Interesting feed from Telecinco on 10958H -
if anyone can check...
12515,V,1399,?
12520,V,7908,? -
