Every night a transponder of "Data" is activated-11024 V,365,3/4, but in fact it has media content,because stream uses codecs and appears to be a stream radio IP? I tried all the codecs that I have installed on my pc,but I have not managed to work out what is transmitted.If someone wants to try,I shall provide a file recorded.
07.0°E Eutelsat 7B
Hi satesco,
can you please upload the original TS capturing?
Hi newsy,
You've got here more than one file from 7.0V-11025 V.I hope you will be able to find out what is this stream. I also tried several players but none was useful.
I have to say that I found many transponders that have such streams.If you're interested,I could send them to you.For now I want to see what you've discovered at 11024 V.
Thanks in advance -
11206 V,2000,3/4 and 11217 V,2000,2/3
Not sure, but I think these are transponders on Africa spot.Could someone check them?Thanks -
Great, who knows!
I see them too but 2.7 dB is not good enough for lock. -
No problem, the answer at this page:
/edit by qwer: LINKS disappeared (01.08.2020).
- ID: Digiturk_UHD
- Freq: 10761.263
- Pol: Horizontal
- SR: 29992.985
- Mod: QPSK2
- FEC: 5/6
- Std: DVB-S2
- 3840 x 2160 pixels ! -
Thanks Noelsat!
Put your post in this toppc here DX>Ku.
Best Regards
qwer. -
11150 V 13775 3/4
ARTE HD / SD -
Not sure, but I think these are transponders on Africa spot.Could someone check them?ThanksTwo data frequencies.(multi+continous str.)
Scan Europe beam B.
Hi newsy,You've got here more than one file from 7.0V-11025 V.I hope you will be able to find out what is this stream. I also tried several players but none was useful.
Thanks in advanceTo find out what it is (apparently no video stream) we could replay it to virtual ethernet adapter and capture a wireshark trace..
12676 H,6427,2/3,Dvb-S2/8PSK-(Empty)
Started a new channel-Yek(test?) on transponder listed on FlySat as test carrier by Enosat.
11345 H,27500,5/6,Dvb-S/QPSK-Channel Yek -
7B-Europe B beam scan.
11345 H,27500=channel yak
stopped program -
Some situations tonight from my place. 4.2Mt.
Interesting feed from Telecinco on 10958H -
if anyone can check...
12515,V,1399,?
12520,V,7908,?
