Natürlich mit der Famaval.
03.0°W ABS-3A
Danke.
Schöne Grüße
qwer.
Poor signal here.
And wrong info on Flysat as usual.
Jetzt kein Signal mehr.
11085 V 10000
Weak signal -
11461 V 3000 1/2 QPSK2 empty carrier, maybe feed will appear...
As far as I have noticed this frequency is active for more than 8 days,I look more like a data transponder.
11462 V 2992 "ABS Promo"
Detecting parameters at 10720 H. 2m.
Later evening came better signal.
Pic from F15.
Locked and analysed,now with PC card.
10720H still goes up!
Nobody else gets this here up in Europe?
11461 V 2992 1/2 ABS test card left, only carrier .
Maximum, I think...
Things are better here even with very bad weather
EIRP Level : 49dBW -
No stormy wind at this time - so my 2.2m "top-of-the-house-antenna" could drive a bit...
My signal on 10720 H.
After doing a scan for feeds 1 hour ago, I have seen this frequency active on H polarization, 11660 H 30000 3/4 S2/QPSK
I don't know if this is new, I think it's from MENA beam.
Signal left only 2-3 minutes later. Reception with 1.4m dish. -
Thanks Excalibur!
I´m on this position right now. 10720 H is possible, as usual.
Big peaks between 11550 to 11630 are from position 3.9°W. :93:
Btw. TC again on 11462 V, not my catch, Gladix on FlySat 11.02.2018.
Maybe this package (11660 H) will be "on air" again later...
Hi EXCALIBUR,
Please check 12698 V,35000,5/6. With my antenna I can't lock it
12725 V,7500,3/4,8PSK-feed DOHA,
12737 H,12500,7/8-Empty -
12698 V,35000,5/6. With my antenna I can't lock itHi satesco,
12698 V 35000 3/4 DVB-S2 8PSK is already reported by milan58 in Feed>Ku. Lockable here with 11.0dB (DOHA-ENC-01 in clear).
Hi satesco,
12698 V 35000, 9.4-9.5dB on 1.4m dish
12725 V 7500, ~12.5dB
for 12698 V I have moved the antenna 2 steps to West from positioner to obtain max signal, so I think that 12687 V 28800 from 1W is from THOR 7 satellite and comes with high signal, makes reception difficult on small dishes for 3W position.
