03.0°W ABS-3A
Active peak (not lockable from my place atm.) on 11660 H.
/edit carrier:
Reception of RASD TV with 2.1m and cloudy weather conditions
No signal of ABS Info Card -
some thing new here ?!
may be it is MENA Beam ?the orther one 12571H I can't see it it is looks like a test carrier TP :93: ?!
IQ-monitor say 12571H3073 ! thank you again satescobut there is some thing else 12675H or 12685H or 12690H
if that is true so 12687H&12675H&12695 are the same ! And also GS tp ?! -
every time I have new SR for 12690H,12685H
Because of the BIG carrier width !!! is around 35 MHZ !
but for 12675H is stable SR is 2000
may they trying to make a new one HERE -
My reception of 12677 Hor
Original von Kypros_Pambou
My reception of 12677 HorAnd what is there??? Channel ,feed ,data?
Absolutely nothing in high band from my place (12518 H is Amos-7).
Signal of the day on 10720 H.
Original von marval450
It was an empty carrier until today that is clearly a data GS
a huge SR on 12630 H 63986
Not able to lock it -
hello KooLy
I see it also from here but also can't look it!! :113:always there are problems with this interval 12500-127500H from 3°W
I am not sure may be this interval is from 4°W
1=12536,H,35000,23,16APSK NO LOCKED
2=12566,H,7999,? NO LOCKED
3=12606,H,922,23,QPSK NO LOCKED
4=12630,H,63990,? NO LOCKED
OR may be this interval is a "TEST AREA" -
10839 H,45000,3/4,32APSK-no lock,just 4.9dB,certainly,generi stream(!?)
/edit by qwer: merged in this toppic.
10839 H,45000,3/4,32APSK-no lock,just 4.9dB,certainly,generi stream(!?)my best score on it is 2 dB, which beam ?
not MENA./edit by qwer: merged in this toppic.
Hi KooLy,
Thank you for your response and confirmation
Regards/edit by qwer: merged in this toppic.
Always NO LOCKED from 3°W !!
10839 H 45000 32APSK 3/4 ACM/VCM...certainly GS
12624 H 56000 ? !.....and with 03 more unknown spikes..
[3.0W] 10838 - Horizontal - 44990.256 - 2/3 - DVB-S2/16APSK - CCM
Now Test Card
Not GS/edit by qwer: merged in this toppic.
