10731 H,30000,3/5-MENA spot-nolock
03.0°W ABS-3A
my result here;
3,0m PF, Croatia
Locked , 2m.
Freq. of RASD TV
Since I've been monitoring the signal on the ABS promo transponder-11461 V,3062,1/2,I got the strongest signal in my area today.
11518 V, 30000, 3/5,8PSK is given on FlySat as feed.I don't know if that's the case,that's why I'm posting it here. -
Finally I locked 11462 H,1666,3/4
...just my 10718H 1666
Wrong info from FS . Sama TV has SR 1666
Nothing special - only my signal on this old frequency 11462 V - nothing on opposite polarity (11462 H) for me...
12740 V,5169,1/4,QPSK2-Tandberg Service.
It appears another TV program,or who knows,maybe a regular feed,has been activated on this transponder instead of the Capri Network package,which has left.
Because the signal is weaker than I expected,I can't figure out which TV program is broadcasting.But most likely this program is partially encoded by the provider Tandberg, which is why it can not be clearly seen?
What do you think?
added:FFplay errors
Signal on my place.
Thanks pawelwa for trying ,but seeing that your signal at 12740 V is almost at the same level as mine, it makes me think that the provider is intentionally using a special transmission technique(proprietary) for certain dedicated devices?
Of course I'm not sure about that,it needs to be confirmed by those who can decode it.
Regards
Here is my reception this morning
My reception with 2.1m
