03.0°W ABS-3A
  • Wrong info from FS . Sama TV has SR 1666
    Try now and check yourself since there is another one on my spectrum.A little dB is missing to lock it,at least 11014 H :3:
    11184 H,10887,1/2-empty
  • my signal for these new transponders (kooly @FS ...28/01/2021&13/5/2021)
    10715,H,1666
    10717,H,2916
    signals : 13.4dB and 12.1dB
    and for 11467,H,1666 ; 9.1dB signal is not stable !
    Ku: 1.80m OS (Testing.....)
    C: 1.80m PF
    C-Band LNB:Panorama ER861
    C-extended LNB: Bwei 5750Mhz
  • 1.8m Cloudy France
  • 10718 locked on limit, 10716 still not locked with even 8,3 db .:51:
    E:10716 Has 5/6 ,noticed later.
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
  • Finally, I locked the two transponders on the MENA spot, 10714 is at the limit, and 10717 V is locking more easily.
    If 10714 had at least fec 3/4 there would be no reception problems :25:
