03.0°W ABS-3A
  • Wrong info from FS . Sama TV has SR 1666
    Try now and check yourself since there is another one on my spectrum.A little dB is missing to lock it,at least 11014 H :3:
    11184 H,10887,1/2-empty
  • my signal for these new transponders (kooly @FS ...28/01/2021&13/5/2021)
    10715,H,1666
    10717,H,2916
    signals : 13.4dB and 12.1dB
    and for 11467,H,1666 ; 9.1dB signal is not stable !
    1.8m Cloudy France
    2.2m Cloudy Germany :83:
  • 10718 locked on limit, 10716 still not locked with even 8,3 db .:51:
    E:10716 Has 5/6 ,noticed later.
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
  • 10715 H 1666
    10718 H 2916
    180 PF Invacom LNB ( Temp 0C)
    location Istanbul TURKEY
    The same 2 signals from Rome (Italy), 1mt dish, TBS 5925
  • Finally, I locked the two transponders on the MENA spot, 10714 is at the limit, and 10717 V is locking more easily.
    If 10714 had at least fec 3/4 there would be no reception problems :25:
    10715,H,1666
    10717,H,2916
    Summer ´22 check on 2.2m - but I´m NOT POSITVE on these ones. :77:
  • Reception of 10716 & 10718 Hor
  • Excellent reception,Kypros :73: , but I wonder if you can pick up the signal from the Southern Africa beam?
    This is much further away from your area(dx) than the MENA spot(dth).
    Thanks :3:
    Thanks :3:
    Unfortunately my friend there isn't any sign from SA beam ........ :88::88:
    Owner of Cy Satellite Center
  • 10715,H,1666
    10717,H,2916
    ...getting more "positive" today - both (of course) not possible on my setup (about 6.5dB more needed)... :26.
  • RASDTV 11.467 H 1.667 with 3,7m easy possible ( 10dB)
    Great that you locked 11467 H, but it would be good to see the spectrum :3:
  • Just my poor signal on MENA beam (2.2m).
    10715 H 1666 (7.0dB under LM)
    10718 H 2916 (5.3dB under LM)
    No signal on 11467 H 1667.
