    Original von superdish66
    3982 H 533 5/6 DVB-S2 QPSK
    New data, I think
    Tried again with EsPro on narrow range from 3840H to 3925H via Epsilon Mode
    Found two more new data with small SR
    3980.45 H 314 3/4 DVB-S2 QPSK
    3981.57 H 314 3/4 DVB-S2 QPSK
    Now I cleaned the situation of these new DAta. The are three SR 314 plus one SR 533
    Here including:
    3980.83 H 314 3/4 DVB-S2 QPSK
  • Excellent superdish66 that you caught and locked these transponders with low symbol rate. :76:
    Happy New Year 2020! :72:
  • superdish66 ,my report here
    Others are probably IP too. :72:
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Original von marval450
    Hi Marval, I didn't have a look in that section. Thank you very much for confirmation. :72:
    RotorFeed: C LR/HV+KU H/V
    TBS5925-6983+6908
    RC2000C
    Edited once, last by superdish66 (January 9, 2020 at 12:19 PM).
  • New here:
    3839 H 16408 3/4 DVB-S2 8PSK
    :49:FYI: I will be out in "C-band" for the next time... (actuator must be changed)
    Probably new here:
    3842 H 18355 3/4 DVB-S2 8PSK (about 4-5dB less signal)
    Probably new here:
    3810 H 8419 3/4 DVB-S2 8PSK
    Probably new here:
    Changed parameter:
    3811 H 9182 3/4 DVB-S2 8PSK
  • 3842 H 18355 3/4 DVB-S2 8PSK
    Changing SR now:
    3842 H 9670
  • New here:
    3809 H 6120 3/4 DVB-S2 8PSK
    3847 H 8738 3/4 DVB-S2 8PSK
  • New here:
    3932 V 4340 3/4 DVB-S
  • just my signal :3:
    probably all these 03 TPs are IP over DVB
    this last one remember me to that one in 31.5°W
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
    C-Band LNB:Panorama ER861
    C-extended LNB: Bwei 5750Mhz
  • 3932 V 4340 DVB-S QPSK 3/4 - NOT NEW
    TBS5925-6983+6908
    RC2000C
  • 3842 H 9670
    Changing again SR now to:
    3842 H 4500 3/4 DVB-S2 8PSK
  • New I think...
    3970 H 4500 3/4 DVB-S2 8PSK
