03.0°W ABS-3A
  • Lock 3929 V.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
    Some changes for the list:
    3791 H 4817 - new
    3812 V 21666 - changed SR
    3819 V 11328 - new
    3870 V 1000 - changed SR (already in two scans before by feci01)
    New (3775 H left): 3776 H 8786
    ...lot of no-locked in S2.
  • ANew scan jeager one polar c band lnb.
    New 3912 H 55235.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
  • New scan.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    Just my linear vertical scan - these (GS) ones appeared already in feci01 scan above...
    3801 V 21900
    3833 V 10000
    Probably new here:
    3925 V 27825
    3965 V 29535
    Changes for the list:
    3851 V 6666
    3858 V 5250
    3870 V 1666
    3912 H 55230 and MIS 1
    4059 V 1666
    Lockable today: 3710 H 827 and MIS 171
    PS. 3912 H 55230 and MIS 1 - still lockable (not in my scan here)
    New for the list:
    4065 V 64000
    Some changes here.
    On again: 3801 V 21900
    Changed SR:
    3750 H 6893 and MIS 171 (locked with TBS6903X)
    New:
    3772 H 15295
    3984 H 7272
    New for the list:
    3917 H 45000
    4158 V 45000
    New for the list:
    4153 V 16930
    Probably new here - scan.
    3755 V 3397
    New for the list:
    4149 V 18900
    Hallo ,
    was ich bekommen locken konnte.
    Ein paar Transponder sind mir unbekannt.
    what I could get lure.
    A few transponders are unknown to me.
    Scan - one changing for the list:
    3735 V 2590
    Man kann schon eine grosse Unterschied zwischen eine 1,80 Antenne und eine 4.9 Antenne sehen :26.
    Was zu beobachten ;
    mit IQMonitor locke ich auf 4030 V 1000 3/4 32APSK einen Transponder
    den bei Dir ( auch mit 4,9m) nicht zu sehen ist
    Mehrmals habe ich am Tag probiert , ist immer da.
    You can already see a big difference between a 1.80 antenna and a 4.9 antenna :26.
    What to watch ;
    with IQMonitor I lock on 4030 V 1000 3/4 32APSK a transponder
    which is not to be seen with you (also with 4.9m).
    I have tried several times during the day, it is always there.
    Moved back on this position - nothing to see with CrazyScan, even not in manual scan.
    /edit: Okay, I found it out: 3930 is from circular signal at 1.0°W - so my scans below are a bit OT...
  • New here:
    3824 H 15000
