Middle East beam - scan 10700 - 11300 (V)
04.1°W Amos-3 <Middle East>
Great catch from "Yes" packages on 10972 V, 11009 V and 11258 V, Megadish!
Nothing here...
11658 V 8520 2/3 DVB/S
Today on my place 10-11% OB X 810 -
früher ein häufiger Gast, der 11658 V, die Israelis, heute nicht mehr empfangbar bei uns im Westen. Schade!
Ja, auch ich bin nach pawelwas Meldung drauf, aber leider kein Signal.
Thanks for your post pawelwa!
No chance in southern of Germany (with 2.2m). -
Today lock.
11658 V 8520 2/3 DVB/S -
On again:
Active again;
4°W Europa
11421,H,3799,12,NBC_QPSK- 12,2dB
11424,H,1899,35,NBC_QPSK- 14,4dB
Can someone check.
These two frequencies are active for more than 24 hours,maybe the PLS. -
is anyone just aible to check both tp 11647 V 8518 and 11657 V 8520
for example our friend pawelwa; I think this day we have a very good signal.
thanks and regards -
Hi Kleinraisting
No signal at my place
Tried again, no signal here (11647 V, 11657 V), too bad situation for 2.2m and 5°W position (11637 V 30000)...
danke Dir; genau das beschrieb ich anderswo; Einflussnahme des 5 West.
schöne Weihnachtsgrüße
My reception with 2.1m & TBS 5925 usb
QuoteOriginal von Kypros_Pambou
My reception with 2.1m & TBS 5925 usb...20,9dB on 2.1m dish (11647 V)!
Great!
If i remembered correct the highest signal with my 2.1m was @ 46E with 21.7dB
I made also with the same card but with my bigger dish (AMS 3.4m ) a reception of the specific frequency
I have and a cloudy weather against me ...... -
11450 - 11700 V Middle East Beam
Lock is always there but no dB display
QuoteOriginal von dreamsat
Hallo dreamsat,
bei schwachem DVB-S Signal mache ich es so:
Sofort (in Sekundenbruchteilen) nach dem Lock den "DVB" button drücken, um den Stream z.B. via VLC player zu öffnen. Das zuvor gelockte Signal bleibt meist da, wenn es ausreichend stark ist... Viel Erfolg.qwer.
But bad BER, probably close to a lock, you can thanks the modulation
Record the ts during a couple of minutes and play it with transedit , you may have a better result.
Just an idea... -
