04.1°W Amos-3 <Middle East>
    Great catch from "Yes" packages on 10972 V, 11009 V and 11258 V, Megadish! :76:
    Nothing here...
  • früher ein häufiger Gast, der 11658 V, die Israelis, heute nicht mehr empfangbar bei uns im Westen. Schade!
    1 Gib. 150
    1 T90
    1 Gib. 125
    Ja, auch ich bin nach pawelwas Meldung drauf, aber leider kein Signal.
    Thanks for your post pawelwa! :73:
    No chance in southern of Germany (with 2.2m).
  • is anyone just aible to check both tp 11647 V 8518 and 11657 V 8520
    for example our friend pawelwa; I think this day we have a very good signal.
    thanks and regards
    1 Gib. 150
    1 T90
    1 Gib. 125
    Tried again, no signal here (11647 V, 11657 V), too bad situation for 2.2m and 5°W position (11637 V 30000)... :91:
  • danke Dir; genau das beschrieb ich anderswo; Einflussnahme des 5 West.
    schöne Weihnachtsgrüße
    1 Gib. 150
    1 T90
    1 Gib. 125
  • My reception with 2.1m & TBS 5925 usb
    Original von Kypros_Pambou
    ...20,9dB on 2.1m dish (11647 V)!
    Great!
  • If i remembered correct the highest signal with my 2.1m was @ 46E with 21.7dB :69: :69:
    I made also with the same card but with my bigger dish (AMS 3.4m ) a reception of the specific frequency
    I have and a cloudy weather against me ......
    Original von dreamsat
    Lock is always there but no dB display :37:
    Hallo dreamsat,
    bei schwachem DVB-S Signal mache ich es so:
    Sofort (in Sekundenbruchteilen) nach dem Lock den "DVB" button drücken, um den Stream z.B. via VLC player zu öffnen. Das zuvor gelockte Signal bleibt meist da, wenn es ausreichend stark ist... Viel Erfolg.
    qwer.
    :125:
    But bad BER, probably close to a lock, you can thanks the modulation
    Record the ts during a couple of minutes and play it with transedit , you may have a better result.
    Just an idea...
