New v.StreamReaderExEx-BDA -1.2.4.99 in 04.07.2020
Neue StreamReaderEX-BDA
What are the changes in it?
I didn't find anything new.
It should be for TBS6903X. -
Confirm that 6903x v2 isn't supported with str.reader 1.2.4.96. I will test with 1.2.4.99 and i hope to see better results . I noticed that at TBS main webpage exist a topic of 6909x v2. Probably they will make the same with 6903x
Original von Kypros_Pambou
Confirm that 6903x v2 isn't supported with str.reader 1.2.4.96. I will test with 1.2.4.99 and i hope to see better results . I noticed that at TBS main webpage exist a topic of 6909x v2. Probably they will make the same with 6903xThe TBS6903x V2 card already exists. I've been testing it for a few days. The results are the same as with the TBS6903x version. The only difference is the missing fan and minor changes to the board.
Original von Peon
Hi to everyone. I agree with you but on TBS 6903x v2 work fine only with crazyscan 1.0.2.165 and stream v 1.2.4.199. I don't know if 6903x v1 works properly with previous versions of crazyscan ..... -
Peon or Kypros_Pambou or anyone else with a 6903x, can you please record a stream for me on 33E 12543V?
Please make sure that Frame mode is commented out in ini File
;FrameMode=1
New StreamReaderExEx-BDA-v.1.2.4.100 in 29.11.2020
New StreamReaderEx for BDA Tuners-1.2.4.101(in 4.01.2021)
I copied the streamreader 1.2.4.101 in the directory of IQMonitor, start the program and "lost" all devices.
If I re-copy the 1.2.4.100 it's all ok again.
The same problem with EBSpro.
All changes before was without this problem.
It doesn't work on my two PCs with high-resolution graphics, but it does on the older PC. But why does the streamreader 1.2.4.100 work then?
Ich habe den Streamreader 1.2.4.101 in das Verzeichnis von IQMonitor kopiert, das Programm gestartet und alle Geräte "verloren".
Wenn ich den 1.2.4.100 erneut kopiere, ist alles wieder in Ordnung.
Das gleiche Problem mit EBSpro.
Alle vorherigen Änderungen waren ohne dieses Problem.
Es funktioniert nicht auf meinen beiden PCs mit hochauflösenden Grafiken, wohl aber auf dem älteren PC. Aber warum funktioniert der streamreader 1.2.4.100 dann?
Because there are some changes in version 101.
The explanation could be done by its author, respected CrazyCat.
I know Peon.
After joint tests with Isotrop and Stephan94 i can say it works with crazyscan, but not with IQMonitor and EBSpro.
New StreamReaderExEX for BDA Tuners-1.2.4.101-Date modified:20.06.2021 21:02
The same problem like the previous version 101, no devices selectable in IQMonitor. With EBSpro and Crazyscan works.
Das gleiche Problem beim IQMonitor wie in der vorigen 101 Version, kein Tuner ist auswählbar. Mit EBSpro und Crazyscan funktioniert es.
Totally agree with FEMI
the devices liste in IQmonitor & IQmonitor-lite is not showing up with this streamreader version too
but you can forced to work with IQmonitor if you know the number of your devices when you connect it to you computer
in my case :
when only TBS5927 is connected ...TBS5927 becomes Device N°0
when both TBS5927 & TBS5521 are connected ...TBS5521 become Device N°0 and TBS5927 becomes Device N°1
unfortunately the Name of the Device will not appears in IQmonitor's Feed-report
New StreamReaderEx 1.2.4.109 --http://crazycat69.narod.ru/sat…/StreamReaderExEx-BDA.rar
*Gold code setup fixed
* Streaming for M88RS6060-based devices fixed
* TBS BLScan2 for M88RS6060 implemented (BLSCan2 with HWControl=0 in streamreader.ini) -
Thanks setesco,
but now I'm confused the last version was 101 and now an update from 99
Tested Version 111:
Still not recommended for IQMonitor 2.4.0.7 or lower - no DBV-cards are displayed.
