Neue StreamReaderEX-BDA
  • New v.StreamReaderExEx-BDA -1.2.4.99 in 04.07.2020
    Loc:Romania.
  • What are the changes in it?
    I didn't find anything new. :88:
    It should be for TBS6903X.
    TBS5925, TBS6983, TBS6903, TBS6903x, TBS6903x V2, TBS6522, TBS5520SE, TBS5927, TBS5590, Prof7301, PF 250cm, ADE antenna 370cm, Full band LNBs: S, L, C Norsat PLL ,X PLL, Ku NJR2842S PLL, full Ka band PLL, and other iron for DX reception, 53W - 98E.
  • crazycat says this vers is for 6903X and 6909x and has partial support.It's a test build.
    For now I didn't notice any major changes :72:
    Loc:Romania.
  • Confirm that 6903x v2 isn't supported with str.reader 1.2.4.96. I will test with 1.2.4.99 and i hope to see better results . I noticed that at TBS main webpage exist a topic of 6909x v2. Probably they will make the same with 6903x
    Owner of Cy Satellite Center
    TBS 6985,6983,6925 PCI,5925usb
    Pace & Arris IPTV Gateways
    AMS 3.4m & Titosat 2.1m motorised
    Original von Kypros_Pambou
    The TBS6903x V2 card already exists. I've been testing it for a few days. The results are the same as with the TBS6903x version. The only difference is the missing fan and minor changes to the board.
    Original von Peon
    Hi to everyone. I agree with you :73: but on TBS 6903x v2 work fine only with crazyscan 1.0.2.165 and stream v 1.2.4.199. I don't know if 6903x v1 works properly with previous versions of crazyscan .....
