Neue StreamReaderEX-BDA
  • StreamReaderEx for BDA v.1.2.4.128-26.06.2022 (new)
  • New StreamReaderEx for BDA v 1.2.4.133-13.07.2022
  • Tested StreamReader files with McAffee and Malwarebytes Premium. No viruses detected!
  • Acronis (Static ML), Ad-Aware, AhnLab-V3, Alibaba, ALYac, Antiy-AVL, Arcabit, Avast, Avira (no cloud), Baidu, BitDefender, BitDefenderTheta, Bkav Pro, ClamAV, Comodo, CrowdStrike Falcon, Cylance, Cynet, Cyren, DrWeb, Elastic, Emsisoft, eScan, ESET-NOD32, F-Secure, Fortinet, GData, Gridinsoft, Ikarus, Jiangmin, K7AntiVirus, K7GW, Kaspersky, Kingsoft, Lionic, Malwarebytes, MAX, MaxSecure, McAfee, McAfee-GW-Edition, Microsoft, NANO-Antivirus, Palo Alto Networks, Panda, QuickHeal, Rising, Sangfor Engine Zero, SecureAge APEX, SentinelOne (Static ML), Sophos, SUPERAntiSpyware, Symantec, TACHYON, TEHTRIS, Tencent, Trapmine, Trellix (FireEye), TrendMicro, TrendMicro-HouseCall, VBA32, VIPRE, VirIT, ViRobot, Webroot, Yandex, Zillya, ZoneAlarm by Check Point, Zoner
    all undetected
  • StreamReaderEx for BDA v 1.2.4.133 from 19.07.2022
    -Set freq step for AirScan to 3 MHz
  • StreamReaderEx for BDA Tuners v. 1.2.4.137 from 15.10.2022
    "DiSEqC1.0 (04 lnbs ) * STAB USALS" is not working good for me in this streamreader 124137 ? :40:
    always I see spetrum from A/A1 lnb !
    also I don't have TBS5925 !!! :25:
    no problem using for example the older streamreader 124120 !
    always using the same crazyscan version 102178 :25:
    I don't know if i wrong or not :40: but I don't have problem with IQmonitor with the same streamreader 124137 !
    Edited once, last by flie: adding more info ().
  • remove Multiswitch , only Diseqc (1.0) and Rotor (1.x)
  • Always the same problem even with older Crazyscan version 102168 and this new streamreader 124137 !!!
    always I see spectrum from A/A lnb ! and also TBS5925 !!!!
    the problem is this new streamreader 124137 I think :25:
  • Hello fie,
    the streamreader don't switch diseqcs.
    I have tesetd the latest CS 178 and all diseqc's are working (A/B and B/A are twisted in Crazyscan)
    As far as USALS is concerned, I can't try anything unfortunately.
    I think the problem is with the diseqc switch.
  • I have tesetd the latest CS 178 and all diseqc's are working
    very strange ! are you using streamreader 124137 with cs 102178?
    because when i use streamreader 124137 devices list changed also diseqc not working well ?!
    but when I use streamreader 124133 every things work!
  • are you using streamreader 124137 with cs 102178?
    yes
    in my streamreader.ini:
    ;! Voltage boost (+1V)
    VoltBoost=0
    ;! Force High voltage before Diseqc cmd
    DiSEqCHV=1
    you can also try
    VoltBoost=0
    DiSEqCHV=0
  • yes
    VoltBoost=0
    thank you very much femi :70::74: for advice ,it was voltboost which make this problem to me :73:
    I remember one time strannik :70: talk about it here , but I didn't realize it until now ! :77:
