Neue StreamReaderEX-BDA
Gute Wetterverhältnisse und auch binnen weniger Minuten, also sehr zeitnah gescannt.
Mir fiel schon bei der TBS6908 auf, dass mit dem neuen Streamreader einige Transponder Schwächen zeigten.
Good weather conditions and also within a few minutes, so scanned very promptly.
I already noticed with the TBS6908 that some transponders showed weaknesses with the new stream reader.
TBS6908 SR148-2
TBS6908 SR154
CS
the transponder-list of this 4 scans to compare
Even if you didn't do the test with 6904se, I could notice that even from an "aesthetic" point of view, the spectrum with 6908 is not very good-looking.
Maybe with 6904se, there will be differences in signal quality and errors on the spectrum, like mine.
I did not check the last StreamReader(1.2.4.154) with other dvb cards, but only 6902se, because the change was made for this card. It is obvious to notice on the spectrum what the differences are both in signal appearance and muxes.
I did the test on Astra 19.2E, where I have a very good signal, which should reduce many errors. But as you can see, 12728 V is not even locked with SR 1.2.4.154, plus another mux appears on the Horizontal, which SR 1.2.4.148 does not find.
it's normal with different cards, but why with different streamreaders.
Version 1.2.4.155 is out now...
Thanks, femi, for the info
Here is StreamReaderEx v.1.2.4.155 from 29.05.2023
Die Ergebnisse der 1.2.4.155 sind deutlich besser.
The results of 1.2.4.155 are significantly better.
Ein Vergleich mit der TBS6908 (16°E, K-Band sub D)
IQM 1020 mit Streamreader 1.2.4.140 auto und zusätzlich manuelle Suche sowie
IQM 1030 mit Streamreader 1.2.4.155 auto und zusätzlich manuelle Suche.
Optisch ein wenig unterschiedlich, aber gleiches Ergebnis.
A comparison with the TBS6908 (16°E, K-Band sub D)
IQM 1020 with stream reader 1.2.4.140 auto and additional manual search as well
IQM 1030 with stream reader 1.2.4.155 auto and additional manual search.
Visually a little different, but same result.
New StreamReaderEx BDA Tuner v.1.2.4.156 from 4.06.2023
-spectrum scan mode when RFScan+FFTScan supported (m88rs6060 devices)
StreamReader version 1.2.4.156 works only with Crazyscan, version 1.0.2.179.
It should be noted that FFTScan is only for m88rs6060 devices (#43)
New StreamReaderEx BDA Tuner v.1.2.5.157 from 7.06.2023
Quoted from CrazyCat post with my English translation. Draw your own conclusions...
CrazyCat » 07 июн 2023, 19:59
ZitatMikroniks2020 писал(а): ↑07 июн 2023, 01:15Проверил 6903х первый блиндскан работает хорошо, показывает какe. частоту сканирует, можно паузу поставить.
А вот второй работает, но не показывает на какой частоте в данный момент и паузу не поставить, если остановить идет дальше... Не ужели не могли сделать тоже нормально в ebs pro.
При настройках 10700-12750 и H, остановилсЗабыл заглушить кривой BLScan2 для 6903x, 6909x в последнем стримридере [Blockierte Grafik: https://satdx.club/images/smilies/dirol.gif] Но там и BLScan крайне тормознутый
I forgot to mute the BLScan2 curve for 6903x, 6909x in the latest streamer [Blockierte Grafik: https://satdx.club/images/smilies/dirol.gif] But there BLScan is extremely slow
My 6903x crashed with CS and EBSpro.
The 6904SE is partial working with both programs.
The 6908 works, but produced an ungly spectrum
I think this version ist forgettable.
New StreamReaderEx BDA Tuner v.1.2.5.158 from 10.06.2023
I will not recomande this streamreader 1.2.5.158 too , you can't use Blindscan2 in Crazyscan with TBS6903X
it is big loss of speed !
New build StreamReaderEx BDA Tunerv.1.2.5.158 from 27.08.2023,
-FrameMode=1
-FrameMode=1
The last change to StreamReader with FrameMode=1 makes sense for those working with 6903x/6909x cards to be able to read generic streams, especially for the TransEdit app, which was previously Encapsulated and displayed only PID 280 or 270. With this change, the Coding Mode no longer shows CCM mode, but as with other cards, ACM/VCM.
To get this, you must remove the semicolon symbol on FrameMode=1 in .SR.ini:
;TrickAPSK=1
FrameMode=1
;ForceAccept=1
;DemodMode=1
;ACM=0
Of course, this change is not mandatory or necessary. It is a matter of personal choice.
Here is how it looks before and after the modification on a mux with S2X extension:
It's a pity that the card does not correctly process other standard pids besides NIT
Code
Alles anzeigen--------------------------------------------------------- Transponder PID-Scan... --------------------------------------------------------- PID found: 0 (0x0000) [SECTION: Program Association Table (PAT)] PID found: 16 (0x0010) [SECTION: Network Information Table (NIT) - actual network] PID found: 17 (0x0011) [SECTION: Service Description Table (SDT) - actual transport stream] PID found: 36 (0x0024) [SECTION: Program Map Table (PMT)] PID found: 37 (0x0025) [SECTION: Program Map Table (PMT)] PID found: 38 (0x0026) [SECTION: Network Information Table (NIT) - other network] PID found: 1347 (0x0543) [SECTION: DSM-CC - private data section // DVB datagram] PID found: 2098 (0x0832) [SECTION: ATSC reserved] PID found: 2099 (0x0833) [SECTION: ATSC reserved] PID found: 2356 (0x0934) [SECTION: User private] PID found: 5632 (0x1600) [unknown]
mainly DSM pid 1347
Code
Alles anzeigenPID: 1347 (0x0543) Guess table from table id... DSM-CC DATAGRAM-decoding.... Table_ID: 62 (0x3e) [= DSM-CC - private data section // DVB datagram] section_syntax_indicator: 1 (0x01) private_indicator: 0 (0x00) reserved_1: 3 (0x03) Section_length: 1069 (0x042d) MACaddrbyte/DevicdID 6: 2 (0x02) MACaddrbyte/DeviceID 5: 0 (0x00) reserved_2: 3 (0x03) payload_scrambling_control: 0 (0x00) [= unscrambled] address_scrambling_control: 0 (0x00) [= unscrambled] LLC_SNAP_flag: 0 (0x00) current_next_indicator: 1 (0x01) [= valid now] Section_number: 0 (0x00) Last_Section_number: 0 (0x00) MACaddrbyte/DeviceID 4: 1 (0x01) MACaddrbyte/DeviceID 3: 94 (0x5e) MACaddrbyte/DeviceID 2: 0 (0x00) MACaddrbyte/DeviceID 1: 1 (0x01) => MAC-Address/DeviceID: 01:00:5e:01:00:02 IP_datagram_bytes: Version: 4 (0x04) IP header length: 5 (0x05) Type of service: 0 (0x00) Total length: 1056 (0x0420) Identification: 17786 (0x457a) Reserved: 0 (0x00) DF: 1 (0x01) MF: 0 (0x00) Fragment offset: 0 (0x0000) Time to live: 4 (0x04) Protocol: 17 (0x11) [= UDP] Header checksum: 37384 (0x9208) Source address: ac130034 [= 172.19.0.52] Destination address: ef010002 [= 239.1.0.2] UDP_datagram: Source port: 34270 (0x85de) Destination port: 49169 (0xc011) Length: 1036 (0x040c) Checksum: 5911 (0x1717) Data 0000: 00 03 38 80 5a bb 72 44 74 1d 64 1d 9a 5d fe 85 ..8.Z.rDt.d..].. 0010: f2 af 3a 4c 45 a9 78 c8 03 bf 54 5a 70 54 a3 18 ..:LE.x...TZpT.. ...
Ich habe folgende Streamreader verglichen.
I have compared the following stream readers.
StreamReaderEx BDA Ver:1.2.4.143
StreamReaderEx BDA Ver:1.2.5.158
Hierzu habe ich nach einem SetChannel die Signalinfo abgefragt.
To do this, I queried the signal info after a SetChannel.
Das Ergebnis ist recht unterschiedlich.
The result is quite different.
StreamReaderEx BDA Ver:1.2.4.143:
Auffällig ist:
SR zeigt nicht alle Transponder als gelockt an, obwohl ich Daten empfange.
Die Transponderabfrage mit SignalInfo zeigt bei der Polarisation immer Horizontal an.
SR erkennt in der Version keine GCS Streams und kein ACM Coding.
It is noticeable:
SR does not show all transponders as locked, although I am receiving data.
The transponder query with SignalInfo always shows horizontal polarization.
SR does not recognize GCS streams or ACM coding in this version.
Hier fällt auf das SR GCS erkennt, aber nur diese Transponder als gelockt kennzeichnet.
Auch hier wird Pol als Horizontal angegeben.
Here it is noticeable that SR recognizes GCS, but only marks these transponders as locked.
Here too, Pol is specified as Horizontal.
Die letzten Streamreader Versionen sind Testversionen.
Nicht ganz umsonst empfiehlt strannik für den IQMonitor je nach Version eine bestimmte streamreader Version.
Viele Karten, darunter auch die 6903x, halte ich nicht für sehr qualifiziert.
An deinem Test zweifle ich jedenfalls nicht, aber Danke für die Mühe.
The latest Streamreader versions are test versions.
It's not entirely for nothing that strannik recommends a specific streamreader version for the IQMonitor, depending on the version.
I don't think many cards, including the 6903x, are very qualified.
In any case, I don't doubt your test, but thanks for the effort.
