Neue StreamReaderEX-BDA
  • The spectrum with the latest version of StreamReader (1.2.4.154) differs from previous versions and seems to give parameter errors.
    femi,
    Please check 6904se. Here is the difference on the spectrum between versions.
    Thanks :72:
  • Gute Wetterverhältnisse und auch binnen weniger Minuten, also sehr zeitnah gescannt.
    Mir fiel schon bei der TBS6908 auf, dass mit dem neuen Streamreader einige Transponder Schwächen zeigten.
    Good weather conditions and also within a few minutes, so scanned very promptly.
    I already noticed with the TBS6908 that some transponders showed weaknesses with the new stream reader.
    TBS6908 SR148-2
    TBS6908 SR154
    CS
    the transponder-list of this 4 scans to compare
    0390_transponders.zip
  • Even if you didn't do the test with 6904se, I could notice that even from an "aesthetic" point of view, the spectrum with 6908 is not very good-looking.
    Maybe with 6904se, there will be differences in signal quality and errors on the spectrum, like mine.
    I did not check the last StreamReader(1.2.4.154) with other dvb cards, but only 6902se, because the change was made for this card. It is obvious to notice on the spectrum what the differences are both in signal appearance and muxes.
    I did the test on Astra 19.2E, where I have a very good signal, which should reduce many errors. But as you can see, 12728 V is not even locked with SR 1.2.4.154, plus another mux appears on the Horizontal, which SR 1.2.4.148 does not find.
  • Maybe with 6904se, there will be differences in signal quality and errors on the spectrum, like mine.
    it's normal with different cards, but why with different streamreaders. :25:
  • Version 1.2.4.155 is out now...
  • Thanks, femi, for the info :72:
    Here is StreamReaderEx v.1.2.4.155 from 29.05.2023
  • Die Ergebnisse der 1.2.4.155 sind deutlich besser.
    The results of 1.2.4.155 are significantly better.
    0390_transponders_155.zip
  • Ein Vergleich mit der TBS6908 (16°E, K-Band sub D)
    IQM 1020 mit Streamreader 1.2.4.140 auto und zusätzlich manuelle Suche sowie
    IQM 1030 mit Streamreader 1.2.4.155 auto und zusätzlich manuelle Suche.
    Optisch ein wenig unterschiedlich, aber gleiches Ergebnis.
    A comparison with the TBS6908 (16°E, K-Band sub D)
    IQM 1020 with stream reader 1.2.4.140 auto and additional manual search as well
    IQM 1030 with stream reader 1.2.4.155 auto and additional manual search.
    Visually a little different, but same result.
  • New StreamReaderEx BDA Tuner v.1.2.4.156 from 4.06.2023
    -spectrum scan mode when RFScan+FFTScan supported (m88rs6060 devices)
    StreamReader version 1.2.4.156 works only with Crazyscan, version 1.0.2.179.
    It should be noted that FFTScan is only for m88rs6060 devices (#43)
