My signal today
50.0°E Turksat 4B
8k test is still active and is there!The big problem is that the signal has a very high fluctuation,more than 6dB,in my area from 8.8dB to 14dB!!!Locked manually.
Correct satesco.Very high signal fluctuation but now i have results on analyzer . Yesterday (specific time ) i haven't unfortunately -
@ qwer, hier der aktuelle Empfang...
Grüße
Original von Isotrop
@ qwer, hier der aktuelle Empfang...Grüße
Danke Isotrop, super!
Hier leider wesentlich schlechteres Signal (11586 H)- aktuell nur 12.6dB....
50.0E_Turksat_8K_test_fec 4/5(new):
For 32APSK 4/5 , 13,6db min, but I can get lock here from ca 15db, BER at 0, ca 15,8 db .
124Mbit video, my PC is sweating.
Lets wait for 5/6 and more...
An unusual way to boost the signal,and so lock the signal,on 11586 H,34284,4/5,32APSK is to set the lnb on C-band even if it is a Ku-band transmission,which in the C-band is 4163.Only with Crazyscan and EBS it can run smoothly the 8K stream.
I hope you succeed too -
Change again the FEC to 3/4
No chance of locking this one from my location but i can see it, it must be on the Eastern beam.
8K promo, added audio track.
8K promo with new TS reader also with thumbnail.
8K not transmitting atm.
8K back on air.
I'm not sure if it's a feed or regular tv program,that's why I post here a service activated,encrypted in RAS,on:11004 H,2500,5/6,8PSK-Service.
8K is off on 11587 H atm. -
There isn't any sign of signal at 11004 H atm( probably was a feed ) and 11587 H is a null tp atm
Turksat 8K is still active at 50.0 E-11586 V,34284,3/4,32APSK
The Turksat_8K transponder is active,but in order to be able to receive it,is important that the signal is strong and stable.The last condition is very important for 8K images to run smoothly.Of all dvbs applications,the best is the TransEdit player,because it manages the signal better even if the signal has a slight fluctuation.If the signal has high fluctuation,TSReader and VLC player crashes.I also add that the stability of the signal depends on the tuner used.For a good reception it is advisable that SNR to be at least 13dB.
So,in addition to the computer's powerful resources,I repeat,strong and stable signal.
I'd like you to tell us what experience you have with Turksat_8K reception at 50.0 E?Thanks. -
It is great that whole world hunts 11675 ,the T2MI pack, no one has signal , nobody asks flysat...
Probably it was only temporary test or?
Confirm that there isn't any signal of 11675 Hor
