05.0°W Eutelsat 5 West B
I can't lock the 12711H due to LTE (12711-10600=2111 MHz in cable)
O_Ku_PMI_E5WA_EU_N02_309
Code
Alles anzeigenGuess table from table id... NIT-decoding.... Table_ID: 64 (0x40) [= Network Information Table (NIT) - actual network] section_syntax_indicator: 1 (0x01) reserved_1: 0 (0x00) reserved_2: 0 (0x00) Section_length: 87 (0x0057) Network_ID: 1 (0x0001) [= Astra Satellite Network 19,2°E | 902 | Satellite | Société Européenne des Satellites] reserved_3: 0 (0x00) Version_number: 0 (0x00) current_next_indicator: 1 (0x01) [= valid now] Section_number: 0 (0x00) Last_Section_number: 0 (0x00) reserved_4: 0 (0x00) Network_descriptor_length: 35 (0x0023) DVB-DescriptorTag: 64 (0x40) [= network_name_descriptor] descriptor_length: 24 (0x18) Network_name: "O_Ku_PMI_E5WA_EU_N02_309" -- Charset: Latin alphabet DVB-DescriptorTag: 74 (0x4a) [= linkage_descriptor] descriptor_length: 7 (0x07) transport_stream_ID: 309 (0x0135) original_network_ID: 0 (0x0000) [= Reserved | Reserved] service_ID: 309 (0x0135) [= --> refers to PMT program_number] linkage_type: 7 (0x07) [= RCS Map] reserved_5: 0 (0x00) Transport_stream_loop_length: 39 (0x0027) Transport_stream_ID: 309 (0x0135) Original_network_ID: 0 (0x0000) [= Reserved | Reserved] reserved_1: 0 (0x00) Transport_descriptor_length: 33 (0x0021) DVB-DescriptorTag: 67 (0x43) [= satellite_delivery_system_descriptor] descriptor_length: 11 (0x0b) Frequency: 18232320 (= 11.63400 GHz) Orbital_position: 80 (= 5.0) West_East_flag: 0 (0x00) [= WEST] Polarisation: 0 (0x00) [= linear - horizontal] Kind: 1 (0x01) [= DVB-S2] Roll Off Faktor: 0 (0x00) [= Alpha 0.35] Modulation_type: 0 (0x00) [= Auto] Symbol_rate: 3418192 (= 34.2850) FEC_inner: 0 (0x00) [= not defined] DVB-DescriptorTag: 121 (0x79) [= S2_satellite_delivery_system_descriptor] descriptor_length: 2 (0x02) scrambling_sequence_selector: 0 (0x00) multiple_input_stream_flag: 1 (0x01) backwards_compatibility_indicator: 0 (0x00) reserved_future_use: 28 (0x1c) input_stream_identifier: 0 (0x00) DVB-DescriptorTag: 127 (0x7f) [= extension_descriptor] descriptor_length: 14 (0x0e) descriptor_tag_extension: 23 (0x17) selector_bytes: 0000: 00 40 01 16 34 00 00 50 04 03 42 85 00 .@..4..P..B.. CRC: 3770940346 (0xe0c3fbba) ==========================================================
Do you know any information about the new definitions in NIT ?
1, reserved_future_use: 28 (0x1c)
2, DVB-DescriptorTag: 127 (0x7f) [= extension_descriptor]
Now I'm at another position, but when I go back to 5.0W I'll check it out
il mio segnale
There is a promotion for Fransat cardholders, the Bis package works with the Fransat card
