07.0°W Nilesat 201
    21462 L is not a DATA txp this a mini mux with channels.
    21462 L 22500 5/6, 3 Channels FTA, one enc for Orbit
    ERTU 1 & 2
    Great catch Feedsat!
    Thanks, a nice one to celebrate the 2000 posts :55:
    Oops... check this!
    :59:
    Thank you Feedsat!
  • Hi
    Is this package still on air? When i tried yesterday night, i was able to see some signal beneath lock but now its nothing there anymore.
    Greetings
    Fidu
    Yes, signal is still active.
    weak but active.
  • Hi
    Feedsat: Thank you for checking. I tried friday night and got about 3-4 dB with plate. Yesterday night it was then only about 0,5 dB with plate and i needed a very long time to even find this small signal.
    Maybe one day in the future I can lock it :88:
    Greetings
    Fidu
    this is exactly what happens when we are at the edge of a satellite's beam (fringe reception).
    Good luck/lock
  • I tested this position with 220 dish, the TP is visible only on spectrum.(swapped polarities).
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    A quick check , nothing new, same signal level as last scan.
    ERTU 1 & 2
    I can "see" this TP, without lock (of course).
    /edit: one more try on better aligned skew & waveguide (2nd. file).
    2nd. edit: getting frequency and SR (3rd. file).
    Nothing changed for 21462 L... not possible on 1,2m from my place yet.
    I have a dream, that one day...
    ...or probably in one cold night... :83:
    I was wrong, it was a sunny day here (and of course another Kathrein dish)... :83:
    Just a look on this position with 2,2m, using (wrong) Invacom ADF_10 feed and MCL-KP04 PLL LNB with home-made dielectric plate.
    Only data on 21462 L 22500 5/6 DVB-S :79:
    ... not possible with 1,8m from my place at this time. :126:
  • Please Any person Check These...
    21462 L 22500 5/6
    To 103.0°E
    khaled Star
    No sign of signal on my 1.8m setup - checked a few days before at my place. :72:
  • 7w nilesat now has 1 more channel
    TIMESPORT HD which is Terrestrial sport TV used to fed the transmission sites in Egypt.
    It's link between EMPC (studios) and ERTU (transmission sites).
    21462 L 22500 5/6
    Changed in band D in circular left now - using MCL-KP04 LNB on 1.8m.
    Currently I can see a strong carrier on 21462 L - it wasn´t there when I checked some days before.
  • Changed in band D in circular left now - using MCL-KP04 LNB on 1.8m.
    Good My Friend
    Can you Give me screen Shot for Channel Here
    To 103.0°E
