18.0°E AMC-14 (incl.)
  • This is unusual, it's one of the most inclined geo satellites still in use and is circular polarised. It was received using a linear feed. It looks like all slots, except 2 at the low end, are in use. It would be interesting to see what's actually there using circular polarised feeds. I think it's data not GS but perhaps someone else can confirm it. The downlink band is about 12200-12700MHz. It was at about +12.2° latitude at the time of observation.
    The beacon plots are here: RE: Beacon Levels & Spectra
  • At 3 June, AMC-14 started to move slowly from 18.0°E to the West, now at 17.55°E, it will probably hold at 17.5°E soon.
    Maybe this is to reduce the short-term interference to Astra at 19.2°E, that I mention in this topic before?
    In any case for me (without elevation control), it should be a bit easier to get some 12.2...12.5 GHz signals, since Eutelsat at 16°E doesn't use that range.
    Chart below shows the West movement since 1 June.
  • I only get indications on the 2 lower TPs as I'm using a linear feed. However, the beacons are now at different levels to those recorded here RE: Beacon Levels & Spectra
    12694.5 is now ~9dB below 12698.5 whereas it was about 6dB above. That was using the same linear feed as the linked plots. I suppose it's possible I did not peak fully for the earlier plots, I don't have real time tracking.
    Latitude 16.7 deg N (47 deg elev.) at the time of this post.
  • My first contact this evening at about +4.1° inclination (according mechanical limits at this "southern" position with my Egis) - moving rapidly - in linear scan.
    SR changed to 23930 now
    ~ 22 frequencies...
    /edit: At about inclination ~+2.0° "reaching" Astra 1L with 12728 V 23500... :79:
    /edit: At about inclination ~+0.5° "reaching" five more - this time from Astra 1N...
    /edit: At about inclination ~-0.3° "reaching" still one (12728 V) from Astra 1L...
    /edit: At about inclination >-0.7° Astra "has left spectrum again to 99,9%"... duration about 25 minutes,,, :26.
  • Thank you, I just forgot to check crossing 0° but with such weak signals no need to bother here, with 1.2m!
