51.5°E Belintersat 1
  • good to see you here master Mosllam :70:
    yes no signal for 11102,H here ,also 11073 H 2000 is left
    Scan to day :
    1=10970,H,30000,23,2 ;11.1 (4.48) dB; 15:09 21/5/2021
    2=11010,H,28770,34,2 ;11.4 (7.37) dB; 15:09 21/5/2021
    3=11010,V,30000,23,2 ;8.9 (2.28) dB; 15:09 21/5/2021
    4=11050,H,30000,34,2 ;10.1 (2.19) dB; 15:09 21/5/2021
    5=11050,V,30000,23,2 ;8.7 (2.08) dB; 15:09 21/5/2021
    6=11085,H,4165,34,2 ;14.7 (6.79) dB; 15:09 21/5/2021
    7=11098,H,16660,34,2 ;8.3 (0.39) dB; 15:09 21/5/2021
    8=11130,H,30000,23,2 ;10.8 (4.18) dB; 15:09 21/5/2021
    9=11130,V,30000,23,2 ;8.7 (2.08) dB; 15:09 21/5/2021
    10=11170,H,30000,23,2 ;11 (4.38) dB; 15:09 21/5/2021
    11=11386,V,20000,23,2 ;8.3 (4.9) dB; 15:09 21/5/2021
  • scan for vertical polarty.
  • thank you file and thanks to all members too. i benefit a lot from the forum. unfourtiontly many times i can only view the pages of the forum because of Internet restrictions
    from your scan i can understand why here the 11085 H jump for last two weeks from 8., 0 db to 10.5 db now works 24 h
    new 11098 0.0 db in early morning and reach only 2.0 db in afternoon
    some how in primitive way i increase dish diameter from 214 to 235 but with 2.7 cm gab at the end of dish in both sides using tazy mohamed method - add olso a reflective cover aroud lnb and the feed helps now in higher temperature and burning sun
    that helps a little bit - but the dish looks very ugly
    Also use Double thermoelectric peltier cooler - strangly no ice at all in winter while in dec 2016 with only one peltier there is thin ice layer in day time and at night thick
    - in 2016 the peltier come directly from china - in jan 2021 I bought them from a very famous ??? electronic shop in egypt
  • some how in primitive way i increase dish diameter from 214 to 235 but with 2.7 cm gab at the end of dish in both sides using tazy mohamed method - add olso a reflective cover aroud lnb and the feed helps now in higher temperature and burning sun
    very good work !:76:
    just to know ; I think transponders and channels in this south bean are changing every day !
    for example 11010,V,30000 is left now and No signal of it to day ; I don't know may just be temporary ?:25:
    also some channels like PEACE TV was Encrypted yesterday ; now it is FTA !
    also this DATA GS transponder 10958,V,2474 was not active yesterday !
    they are changing something everyday !:80:
  • thanks for confirming - i thought i had a problem
    11010 v had no signal for many days evry time when i check 0db -- on last Tuesday 25 may no signal till 18:40 it works 6.4db
    Wednesday morning 6:00 am"> also working 6.5 db -- now thursday 4:30 am still working 6.6 db
    One more dB needed for 11085 H 4166 3/4 DVB-S2 8PSK, Cloud Ghana mux
    /edit:
    11010 H 28775 3/4 DVB-S2 QPSK "only" 0.7dB under LM now.
  • just checking this position again -south-beam- :3:
    11050H and 11170H are left (Flysat by AhmedIraqi & K.Ahmed 8-9/2021)
  • Just one lock in my position...
    11010 H 28770
    -Winegard Mesh 3.10m
    -Famaval 1.80m
    -Gibertini 1.25m
    -TBS6903 - TBS6902 - TBS6922TE - TBS5520SE
    -MediaKind RX8200
    -58ºW <>53ºE
    -KU + KA + C
    -Loc: Spain
    Edited 2 times, last by bol@nov ().
  • 11230 H and 11290 H again active (but empty)
