Sounds promising! I'll need to get a dielectric plate and try and see whether I need a bigger antenna or not. I hope the interference will let me through; 5G is not a problem in my area iirc, but the elev. angle is going to be a bit less than 2 degrees...
Meanwhile, does anyone have a constant access to that satellite and 3707R mux? I am currently writing a thesis on North Korean mass media and language thereof and I've been deprived of access to it thanks to the satellites switch. Sadly, the only livestream available on the internet is dissatisfactory and basically impossible to work with :( if there's anyone that could temporarily share the 3 channels (1 TV + 2 Radio) with me through internet, until I set up my dish (of course all costs and technicalities on my side), I'd be more than happy to get in contact. I've already looked at countless of IPTV services, with no luck.
When KCTV was broadcast on 87.5E, it was an occasion to watch "the so-called TV programs." They are continuous propaganda for the so-called extraordinary achievements of the communist system and an almost mystical cult of the supreme leader, Kim Jong-Un.
I also made a recording from KCTV at 87.5E., which reminded me of when I lived in Romania when "beloved" Tov. Nicolae Ceausescu ruled communist Romania with an iron hand; the leadership model was taken over by the Romanian dictator from Kim Il Sung, grandfather of the current "supreme" when he visited that country in the 70s.
Where there is much propaganda, there is much lying. Romanians have lived it to the full, and it is no coincidence that Dec '89 was a bloody revolution. The more powerful such a leader is, the poorer that country is.
If you want, I can provide you with the recording from the old position on the arch.
In the meantime, if you think it will help you, you can use the satellite recordings I made for your thesis about the North Korean media as propaganda material and the cult of personality of the current Supreme Leader.
https://www.mediafire.com/file/5ir4jx4ru…3_KCTV.zip/file
