Spectrum of the day
7657 L 2420
7632 L 2420
7323 L 2420
No lock: 7574 L 2465 & 7670 L 7042
Spectrum of the day
7657 L 2420
7632 L 2420
7323 L 2420
New: 7251 L 1505
Scan of the day
7405 L 2420 new
7288 L 1080 new
All LHCP 1.5m PF Dish
4 turn helical feed (under illuminates dish)
1.6dB NF LNA (Miteq + mil surplus)
8.5GHz DRO down converter
7546 L new SR 1480 (but no lock today)
7630 7632 7634 L 1000
no lock
7280 L 2980 new
7622 L 2150 New
7622 has left
7656 L 1419
new 7616 L 4100
Just my first experiences in X-band on 1,2m... please don´t laugh about my signal
...only test-mode on bad aligned feed... ![]()
...in hope, from this position:
7324 L 1575 - changing SR
7685 L 2960 - probably new
Next test with better aligned feed on 1,2m.
Probably new:
7461 L 1000
7674 L 1576
Scan on 1,2m, using a plastic plate inside.
New here:
7463 L 1000
7749 L 1576
PS: added 7674 L in manual scan
Hi qwer, have you checked for the new WGS-10 at 24.0°E already?
Quite close to 25.1°E Skynet 5B.
Hi hvdh,
not checked 24.0°E yet - but I think, my small offset dish will have problems to"split" from this position here... ![]()
/edit: No chance at this time to "see" anything on 24.0°E, sorry.
Just another scan - nothing has changed in spectrum. ![]()
Next test on 1,2m - changing to rectangular feed - without plastic plate.
Low band signal increased - upper band decreased.
/edit: manual scans from lower frequencies.
Scan of the day - new here:
7382 L 2272
Spectrum and BS with TBS 6903 from my place on 1.2m (KATHREIN CAS 120 and rectangular feed) - without elevation control at this time...
New: 7315 L 3990
Not active right now, I think: 7280 L, 7288 L and 7461 L.
7382 L 2272, unlocked with -1.7dB
November try - elevation is okay now from my place.
Unlockable signal (for me) on 7280 L (not using SR 2980).
