08.0°W Eutelsat 8 West B
  • 4153 L 60000 2/3 DVB-S2 8PSK
    Stream3 PLP7
    Stream4 PLP8
  • Just a look here after a longer time. Only one service in clear - "EASYTV" (on MIS 1 PLP 1 and MIS 3 PLP 7).
    Now No Signal In my Home
    Qwer Please Check IT...
    To 103.0°E
  • No more lock for me on 4153 L...
  • Probably new here...
    I have (personal) probs when using VMA Stream Reader, because I didn´t see MIS 171, MIS 173 and MIS 174 - only "MIS 3" appeared,
    so I can´t choose MIS 171 for example....?
    3732 L 40416 2/3 DVB-S2 8PSK, T2-MI
    MIS 171 and PLP 0
    MIS 173 and PLP 2
    PS: [MIS 174 and APid 2003/APid 2004/APid 2005 - ID: FM Radios]
  • I have (personal) probs when using VMA Stream Reader, because I didn´t see MIS 171, MIS 173 and MIS 174 - only "MIS 3" appeared,
    It works in "manual work"... using CrazyScan and tuning in (for example here) MIS 171 and stream to file, than open VMA Transport Stream Analyzer and play TS, after that activate T2-MI Mode and set the correct paramter settings (here: PID 4097 and PLP 0) and launch new Transport Stream Analyzer. After all you can launch VMA Mosic.
  • This is Easy TV Package copy From 22 W
  • Es ist nicht einfach mir nur 1,80m , früh am Tag geht es besser
    Hier was mein Openbox sagt
  • Z.Zeit mit einem SR von 9,3 dB geht es relativ gut bei diesem MIS T2MI 3734 L 40408
    At the moment, with an SR of 9.3 dB, this MIS T2MI 3734 L 40408 is performing relatively well
  • Just another try on VMA tool... :25:
    MIS 171 and PLP 0
    MIS 173 and PLP 2
  • 3732 L 40416 2/3 DVB-S2 8PSK, T2-MI
    3732 L has left...
    3750 L 45822 2/3 DVB-S2 8PSK - new but more than 0.5dB under link margin on 4.9m right now...
    /edit: 25 min later... 3732 L is back... :28:
