21.6°E Eutelsat 21B <Wide/Western>
    Hi,
    just to start a toppic here. :83:
    :101: If someone can get Eastern beam, he can start of course a new toppic, I can´t... :91:
    PS: Very weak signal on 11682 V 2733 5/6 DVB-S and 11686 V 2748 3/4 DVB-S2, probably data.
    /:edit: correct FEC 3/4 for 11686 V, both data services.
    Best REgards
    qwer.
  • Hi qwer,
    Here's what i scanned today at 21.5E:
    Hi satesco,
    thanks for your scans! :126:
    PS: I´m not totally sure if I´m right (a little too small picture), you can´t receive Eastern beam from your location?
    Best Regards
    qwer.
  • Hi qwer,
    After FlySat,no,but perhaps if I had the antenna slightly larger i catch some signal on eastern beam. I don't expect more when the signal is 38 dBW at the edge of the footprint and we're outside of it.
    I hope to see SNR more clearly with EBS
    Great thanks satesco! :125:
  • From my QTH I have weak signals on
    10981 H 5595
    10986 H 1172
    10988 H 955
    :88:
  • Thanks Marval.
    It's interesting because the spectrum looks strong,
    PLS ?
  • on my place there is the same signal like Feedsat after a small raining
    1 Gib. 150
    1 T90
    1 Gib. 125
  • Does any of you has tried a PLS search ?
    PS: 10987 H has changed SR
  • Thanks milan58 for discovered it :76: Signal not too strong.But what contains this transponder?
    regards :125:
    21,6°E
    I still have not managed to unlock new frequencies?
    1=10982,H,5594,35,134,|-2 (-7.8) dB; 8:14 19/12/2016
    1=10986,H,1172,35,134,|-0.4 (-6.2) dB; 8:14 19/12/2016
    2=10988,H,1553,34,134,|2.5 (-5.71) dB; 8:14 19/12/2016
  • 10735 and 10920 V new mux ?
    DVB S S2 S2X not found
    Nothing from here either .... :91:
    Owner of Cy Satellite Center
  • hello,
    10918 H was sometime listented in my receiver; reception 10dB (26° Ost in the middle on 180 dish)
    regards
    1 Gib. 150
    1 T90
    1 Gib. 125
    Original von Kleinraisting
    hello,
    regards
    Feedsat wrote the frequencies with Ver pol. not Hor
    10918 Hor is Bein Package from wide beam
