Both 11599H & 11175V are actually on the wide beam and are incorrectly listed as Eastern beam, I receive both here in the UK with a good signal.
21.6°E Eutelsat 21B <Wide/Western>
Hi SatSearcher,
I think none of us are right about the beam.I/we've kind of forgotten that there is another beam which has a Western coverage.And that explains why the two frequency you receive well in your area.(Below the Western beam map).From this point of view you are right that FlySat places them wrong on the Eastern beam!?!
The only thing that I do not know is why,for example, BWTV(11075 V and 11674 H) is transmitted over two beams that have about the same coverage on the same area:Western and Wide,which overlap on the western side of Europe?
If it is true what I'm saying now,then it means that we still don't have a frequency listed on the Eastern beam and those listed on FlySat are wrong!?That's why it's good that @LooKy,right at the center of this (Eastern)beam,tells us what transponders are receiving in Middle East on Eutelsat 21B?
Here's how I see the beam in the area where I'm picking them up,which I have to say that I'm in a fringe area(Romania) for both beams,Western and Eastern.
If you're curious,then I post the transponder list I receive from the Wide beam in my area.
If I do not ask too much, I would ask you to post the transponder list you get from the Western beam from your area,UK.I get the impression that some of them have other parameters than the lists.Thanks.
Anyway,thank you for bringing me the attention of this beam that I have ignored so far.
Regards -
11577 H,512,2/3,Dvb-S-Radio 1000 and 2000-Qbit GmbH.New service!
What do you think, is on the Western beam,as I said in the previous post, or ...? -
If I get time later on (and if it ever stops raining here!), I will post a full scan of what I receive here in the UK from 21.6E. To be honest it's almost impossible for me to tell which signals are on Wide beam or Western beam from my location, as the footprint maps give an almost identical signal level here! There are some channels listed as Eastern beam which I would say are correct (e.g. 11584H, 11585H, 11595H, 11597H) as I get no signal whatsoever from these. The radio services on 11577H have been there for some time now (they were listed on Flysat but just noticed they seem to have been removed!), although whether they are Wide or West I couldn't say for certain! I get around 11dB on them.
So finally managed to get a scan done, looking at the results of mine in the UK and yours in Romania, I would guess that everything on H polarity after approx 11540 is either on the West or East beam, whereas pretty much everything else is probably on the wide beam, but it's just an educated guess, I could be wrong!
Al Taleaa TV[21.6E] 11558 - Vertical - 1479.7 - 8/9 - DVB-S2/8PSK - CCM
Al Rassd[21.6E] 11564 - Vertical - 2219.534 - 5/6 - DVB-S2/8PSK - CCM
Asia News [21.6E] 11575 - Vertical - 1479.695 - 3/4 - DVB-S2/8PSK - CCM
Asia TV [21.6E] 11574 - Vertical - 1479.69 - 3/4 - DVB-S2/8PSK - CCM -
Not new, I know, only for the screenshot (IP on 11520 H 2220).
11570H9500 SR changed .
A big problem to lock this freq. for me, but I got it.
Mistake on fs ,TXP number is OK, but beam is western.
New TP? Looks like test of Greek Cosmote TV(9E) .
My reception
just my signal
on my place (26 east in the middle) 12,1dB.
test81
test2
test3 all without picture
11237 H 2583 5/6 DVB-S2 8PSK - Changing frequency
already in FS 18.09.2019 G.Abdelhamid & SatSearcher
11259 H 27500 DVB-S 7/8 Not locked ...I think Eastern-beam11344 H 27500 DVB-S 7/8 locked at the limit !!! may be wide-beam ??
who know?
both locked -at the limit- at night !..may be both wide beam after all
FYI flie, I merged your two last reports in this toppic here.
chinese MUX @ 10856 V 30000 QPSK 1/2
....FS ...03/01/2020. -
Original von flie
Encrypted now !
