11099 H 6117 QPSK2 3/4
Canal1,Canal2.
21.6°E Eutelsat 21B <Wide/Western>
11106 H 4539 2/3 DVB-S2/QPSK.CANAL1,CANAL2.
Original von feci01
Nothing atm from this frequency -
I ask anyone who can check both beams,eastern and western,whether 11603 H is active or not?IQmonitor shows me there's a radio program here?Crazyscan can't find it though
Thanks11603 H,256,3/4-Prog 1000/2000
3x Lock der Radios hier mit kleiner Frequenzdrift
No signal with 2.1m. Most possible the tps come from western beam. I will check also and with my 3.4m and if i have a reception i'll post it. -
Thanks @Kypros for the feedback,but the answer I got indirectly from @Isotrop.On this occasion I realized that the three transponders with low-rate symbol,(Radio program) are on the western beam.SNR on our colleague's Crazyscan monitor is cool,and he's receiving it from Germany.
Regards -
But this one is very Remarkable about 24.5 dB !!!
11113,V,400 DVB-S QPSK 3/4... empty .
You're in the center of the spot I got it too in my area,of course with a weaker signal(over 13dB) than yours And it's still empty now.
Today I managed to listen for the first time to the radio package(MFM) at 11614 H,376,3/4,whose signal is on the western spot,which does not even touch my area.In fact,apart from 11604,all with symbol rates I locked on this beam
With IQmonitor other frequencies locked,but I'm not sure of them
you are right Satesco
there are two very close Transponders 11598.3,H,256 & 11598.6,H,185
Best regards
flie
En fine,I managed to lock the symbol rates of 186 on 11604 H,3/4,but also to listen to the radio stream.Until now it was impossible to lock it with Crazuscan,but only with IQmonitor,with my antenna!
Those with big antennas or on the Western spot,should check whether 11600 H,186,3/4 and 11614 H,376,3/4 are active? I didn't see a trace of a signal on these transponders.
Just a look in manual scan... nothing new appeared.
Full scan 21,6ºE
West / Wide beams
...Very good that you posted transponders received from the west beam.For some areas of Europe it is hard to distinguish which ones are from the east spot and which ones are from the west spot.It's a welcome clarification,at least for me.
I'm just surprised that I don't see transponders with low symbol rate from the west spot,especially since you use the tbs6903 card which is as good as the 6983(see my pict).
It seems that 11601 H,1479,5/6 is on the eastern spot, since it has a snr at -10. It's a great performance to get a signal from this spot, especially if you receive the satellite in the western part of Europe.
In my area there is no signal from this transponder although I am further east of your area.
You may already know, but it's good to remember that for some transponders with difficult parameters it's good to scan them manually, especially if they are close to each other. Tbs6983/6903 cards can discriminate better and lock such adjacent transponders.
Regards
ps_which of the three antennas in the profiles did you use for Ku-band reception?It is good to mention this when posting reports!
You may already know, but it's good to remember that for some transponders with difficult parameters it's good to scan them manually, especially if they are close to each other. Tbs6983/6893 cards can discriminate better and lock such adjacent transponders.
Regards
Thanks satesco for your notes, you're right in relation to low SR tps, blindscan skip almost everything below 1000, I can only capture them manually, I don't know if the problem is from TBS6903 or from lnb Inverto.
Let me point out that the West beam scan was done on my 1.80m antenna but the East scan was done with the 1.80m antenna from a friend in Moldova, impossible to capture East beam at my position.
My objective is to present a complete scan on this satellite in all its beams.
Cheers
A new transponder has appeared
