21.6°E Eutelsat 21B
  • Full scan 21,6ºE
    West / Wide beams
    Very good that you posted transponders received from the west beam.For some areas of Europe it is hard to distinguish which ones are from the east spot and which ones are from the west spot.It's a welcome clarification,at least for me.
    I'm just surprised that I don't see transponders with low symbol rate from the west spot,especially since you use the tbs6903 card which is as good as the 6983(see my pict).
    It seems that 11601 H,1479,5/6 is on the eastern spot, since it has a snr at -10. It's a great performance to get a signal from this spot, especially if you receive the satellite in the western part of Europe.
    In my area there is no signal from this transponder although I am further east of your area.
    You may already know, but it's good to remember that for some transponders with difficult parameters it's good to scan them manually, especially if they are close to each other. Tbs6983/6903 cards can discriminate better and lock such adjacent transponders.
    Regards :3:
    ps_which of the three antennas in the profiles did you use for Ku-band reception?It is good to mention this when posting reports!
  • Thanks satesco for your notes, you're right in relation to low SR tps, blindscan skip almost everything below 1000, I can only capture them manually, I don't know if the problem is from TBS6903 or from lnb Inverto.
    Let me point out that the West beam scan was done on my 1.80m antenna but the East scan was done with the 1.80m antenna from a friend in Moldova, impossible to capture East beam at my position.
    My objective is to present a complete scan on this satellite in all its beams.
    Cheers
    -Winegard Mesh 3.10m
    -Famaval 1.80m
    -Gibertini 1.25m
    -TBS6903 - TBS6902 - TBS6922TE
    -MediaKind RX8200
    -58ºW <>53ºE
    -KU + C
    -Loc: Spain
  • Here's what I'm getting at 21.6E at the moment with the Crazyscan, IQmonitor(v.1013) and EBSpro apps.
