sorry, I think its Es'hail 1
25.5°E Es'hail 1 [Eutelsat 25B]
Hi Kleinraisting,
a few tenth dB more and I can lock 11566 H from my place.
PS: Merged in this toppic.
thanks qwer, thats was also my first idea about reception in the priveleged
3 country egde -
Heute morgen.
Nice results in low band, feci01!
Just a scan on 2,2m from my place. Only one TP lockable at this time. Others in upper low band just before lock... but not possible to lock right now.
/3x edit: Finally locked 11642 H and 11669 V a short moment later...
Just on this position.
I can get a manual lock now on 11566 H.
/edit: Finally get the fifth lock of the day (manual scan): 11623 V
Good conditions this morning (8.0°C) for this position from my place.
Complete locks in range 11.500 - 11.700 MHz on TBS 6925.
Especially 11546 V, 11566 H and 11585 V are difficult here.This is not possible with TBS 6903 (check attached file).
/edit:
... locked 11180 V too now, via TBS 6925.
PS: On lock-border: 11065 V.
My scan.
Just a scan from my place (big rainy clouds in the air). No signal for me on 11668 H at this time.
Just showing that TBS 6925 works better for me here as TBS 6903....
Not lockable at this time: 11046 H 27500 2/3 DVB-S2 8PSK - all others lockable!
Peak on 11229 H...
11084 H 3000 is GS (not sure about position?)
Hi Qwer,
I don't have to say that your results are remarkable,perhaps unique.And it is not accidental this,because besides knowing how to make adjustments to your antennas,you have at hand a "forest" of antennas at your disposal,each of these are used for different bands.Of course,for this you can be envied by each of us,to which I add the fact that these antennas are installed in the area without interference of any kind.I'm glad for you that you have such material possibilities but also that you have no interference.
For me,at least,the results obtained by you are a kind of indicator of what each of us could receive with the equipment we have.I'm particularly interested in the spectrum that each of us posts from the receiving satellites,without neglecting the punctual reception that each of us gets.
Considering what I said before but at the risk of giving you extra work,it would be very desirable that when you post spectrum,regardless of the band(C/Ku/Ka/X,etc.),you mention the size of the antenna used.
Each satellite-spectrum posts,regardless of the user,oblige us to compare what we have to compare with the equipment we have.Luckily Crazyscan gives us the opportunity to mention the equipment we use.Outside the C-band,when you use the biggest antenna,over four meters,I didn't know which antenna you used for the Ku,Ka,or X-band.
That's all I want to.Is that too much to ask?Thank you.
Regards
Hi satesco,
thank you for your kind words. No problem to show my reception antennas in the different bands (probably I add them in CS next).
For a given reason (>Satellites lists in this forum), I do not use the footer in my profile, sorry, but rather I use "Wall" for all the stuff...
In words - my motorised antennas - always for each band:
Best regards
satesco - I changed it in CS now...
My scan with TBS 6903 -> 11546 V possible in manual scan today with this card (no problem with Version 6925).
(I can´t lock 11666 V in manual, GS I think)
/edit (a short moment later): got them all in one BS, uff! Also 11180 V is possibele in BS and TBS 6903.
11666 H 3333 2/3 DVB-S2 8PSK, unlocked appeared (- probably feed?)
Locked them all again on TBS 6925...
Summer scan - locked them again.
PS: 11046 H (6.2dB) and 11180 V (5.5dB), unlocked.
August try.
Lockable on TBS 6925:
11547 V 27500 2/3 DVB-S2 8PSK
11566 H 27500 2/3 DVB-S2 8PSK
11585 V 27500 2/3 DVB-S2 8PSK
11604 H 27500 3/4 DVB-S
11623 V 27500 2/3 DVB-S2 8PSK
11643 H 27500 2/3 DVB-S2 8PSK
Attached TBS 6903 scan too.
Not lockable on both cards:
11180 V 27500 2/3 DVB-S2 8PSK
