25.5°E Es'hail 1 [Eutelsat 25B]
  • January 2023 try:
    Lockable on TBS 6925:
    11547 V 27500 2/3 DVB-S2 8PSK
    11566 H 27500 2/3 DVB-S2 8PSK
    11585 V 27500 2/3 DVB-S2 8PSK
    11604 H 27500 3/4 DVB-S
    11623 V 27500 2/3 DVB-S2 8PSK
    11643 H 27500 2/3 DVB-S2 8PSK
    Attached TBS 6903 scan too.
    Not lockable on both cards:
    11046 H 27500 2/3 DVB-S2 8PSK
    11180 V 27500 2/3 DVB-S2 8PSK
  • And lockable on the limit later...
  • Stehe gerade auf der Position und habe mal Scan laufen lassen.
    Suedschwede Setup
    > 2x AX HD51 4k
    > 2x SF 8008 Twin
    > 1x SF 8008 Mini
    > 1x SX 88 V2 Dual
    > 1x Edision Os Mio 4k
    > 1x OpenboxSX6
  • Lockable on TBS 6925.
    Not lockable...
    11046 H 27500 2/3 DVB-S2 8PSK (6.2dB)
    11180 V 27500 2/3 DVB-S2 8PSK (6.5dB)
  • Far away from lock - reported on FlySat 07.06.2023 by KooLy :72:
    11649 V 2244 2/3 DVB-S2 8PSK, Bedaya - about 4.5dB under LM on 2,2m from my place
    Other TP in this range are still lockable on TBS 6925.
  • Here's my situation for this position.
    Much more better than Es'hail 2 with feed that needs some works
    All Freqs. lockable except 11649 V about 2.0dB under LM
    RotorFeed: C LR/HV+KU H/V
    TBS5925-6983+6908
    RC2000C
  • Heute für das erste Mal , konnte ich 11604 H 27500 bekommen :34:
    Today for the first time, I could get 11604 H 27500
  • Das ist der einzige TP auf diesem Satelliten, den ich durchgehend fast 24/7 empfangen kann.
  • Just another scan in 11.45 to 11.70 GHz range...only 11604 H 27500 3/4 DVB-S Aljyzeera package remain, beIn packages left... not new, already reported via stephan94 scan from 26.10.2023 above... :72:
    PS: 11046 H 27500 2/3 DVB-S2 8PSK Aljazeera package not lockable (about 0.6dB under LM)
  • Lockable on the limit via TBS 6925 right now from my place on 2.2m, but too low signal for showing video content:
  • Here's my situation for this position tonight
    TBS5925-6983+6908
    RC2000C
  • Today scan, something new on 11180V. Can somebody check, what there?
    ...arrgh... not lockable yet.
  • Hier die aktuellen Empfangswerte auf Es´hail 1 mit 125 cm.
    Neben dem "Al Jazeera Mux" auf 11604 H findet sich auch ein Feed auf 11068 H mit der Kennung "HD Service 06".
    Der Empfang ist mit Aussetzern möglich. Das Bild gleicht einem Bildschirmschoner.
    Here are the current reception values on Es'hail 1 with 125 cm.
    In addition to the "Al Jazeera Mux" on 11604 H, there is also a feed on 11068 H with the identifier "HD Service 06".
    Reception is possible with dropouts. The image resembles a screen saver.
    Signal on 11180 V left at 12.00 CET ...
    /edit: 11180 V on again ....13.00 CET
    /edit: reaching 7.0dB on 11180 V (just 0.7dB under LM) ....16.30 CET...daily top
  • Just my current scasn from this position in year 2024 on 2.2m from my place.
    11046 H 27500 2/3 DVB-S2 8PSK, Aljazeera (Quatar) - about 0.5dB under LM
    11604 H 27500 3/4 DVB-S, Aljazeera (Quatar) - about 4.0dB over LM
  • Mit 125 cm und dem D15 empfange ich mit Aussetzern bei 5.1 dB das neue SNRT Paket auf 11547 V 27500 3/4.
    Weitere empfangbare Transponder sind: 11687 H mit 5.1 dB und 11604 H mit 5.4 dB ohne Aussetzer.
    With 125 cm and the D15 I receive the new SNRT package on 11547 V 27500 3/4 with dropouts at 5.1 dB.
    Other receivable transponders are: 11687 H with 5.1 dB and 11604 H with 5.4 dB without dropouts.
  • Scans on 2.2m.
    PS: 11547 V 27500 3/4 DVB-S according NIT on Position 25.8°E (Es´hail 2)... :26.
    11046 H 27500 2/3 DVB-S2 8PSK - still under lock (0.5dB)
    11623 V 27500 3/4 DVB-S2 8PSK - under lock (0.7dB)
    PS2: Lockable feeds 11069 H 1666 3/4 DVB-S (on the limit) and 11686 H 1666 3/4 DVB-S (2dB over LM)
  • Three lockable feeds at scan time...
    11652 V 3333 5/6 DVB-S2 QPSK
    11656 V 3333 5/6 DVB-S2 QPSK
    11686 H 1666 3/4 DVB-S2 QPSK, encrypted (Aljazeera feed)
    PS: 11069 H 1666 3/4 DVB-S is also active, but no chance to lock
