4648 V ?
65.2°W Eutelsat 65 West A
one more on 4590 V
4770 V The switch added
4770 H 51420 16APSK 2/3: not a GS stream, let's wait for a lock... (need 1dB)
4556 V 2082 5/6
NCN & Guyanan Learning ChannelPS 4551 V 1667 16APSK 8/9 DATA or GS but not locked yet
4770 V, Eutelsat promo have left the mux
in H now
4688 4697 4706 7072 3/4 but all enc
4556 V. 2082. 5/6.
Looked at this frequency again today - very poor video quality on the HEVC Encoder 1
Original von jaes
4556 V. 2082. 5/6.Looked at this frequency again today - very poor video quality on the HEVC Encoder 1
Thanks 'Jaes' for your contribution, glad to see you again, taking part of this forum
well, you' re right, even if they use HEVC, it doesn't means better quality, it's worth, you know, providers wants the the best result (for themselves) for the less expensive cost , H265 instead of H264 give a better bitrate ratio but nothing about quality 4DTH.
there are 2 very important thing to understand : modulation and encoding typeyou can transmit the worst quality in HEVC DVB.S2 and the best in H264 8PSK/NS3/4
Must of our contributors/readers/followers will probably remenber the asian packages at 70.5 E in HEVC, but 30 to 40 channels per txp doesnt't means good quality for end user ....
regards
PS;: your previous contribution not sharde here, is attached
4735 H 2082 (was not active till this last saturday) -
This mornings Hor scan from central UK, 2.2 PF
my yesterday's scan on 4712 H was proabably a feed because it's off air now
Guys,
Ik have found a Extended C band LNB, for tests on Eutelsat 65. The L.O, must be on 5750, stands on the label. But when I do a Blindscan, IT scans between 6500 and 6700 MHz.
Can someone help me on This?
Ik use a Dreambox 7080.
Jootje
Hello Jootje, I do not have a Dreambox 7080, but please mention the used image as well.
Anyway, if only the range 6500...6700 comes up, that will not work. Probably Extended C-band (4.5...4.8 GHz) is not supported.
Please try setting the LNB L.O. to the usual 5150 MHz, you should at least have the range 3700...4200 MHz available for blindscan.
Then with your 5750 MHz LNB, the 3900...4200 MHz range of your box will correspond to actual 4500...4800 MHz.
So for the real frequency, just add 600 MHz to what the box shows.
Hello HvdH👍
I use the original OE . 2.5 from Dream itself.
Thanks for your fast responce, I wil try your advise, and let you know.
Best regards,
Jootje
