Feedsat's Thread
    something new to explore in the backyard.
    OK, zoom out :83:
    More toys in the packing :70:
    Signature updated
    More pics will follow soon ...
    PS: about previous pictures:
    Uplink kit, including power amplifier X 2 (8 Watt)
    TX/RX CM Kit .
    maybe one day I will be able to broadcast my own feed from home but I need 2 more appliances.
    OK, just finish to clean up the last "baby".
    Very huge mount !
    A little upgrade
    A little upgrade
    Congratulations :76:
    What size is the dish?Where is the actuator for azimuth?
    Regards
    Regards
    2.40m, no az motor yet, I am thinking to install the EGIS (later...)
    New "old" toys arrived today.
    I think an uplink test from my QTH will be possible later this year.
    I have the BUC, the amplifiers (many), the modulator, the Encoder, the complete RX/TX system. Let's see if it will be possible. :126:
    Old DVB-S I know but still working (was active less than a year for a French Channel in SCPC)
    My LNB 'Changer' is now installed on the CM180 , it works well.
    not installed (removed) on the Laminas, too light antenna.
    A new toy is arrived
    An IRD from a Canadian Company Advanced Digital
    ADV-6000S
    Just unpacked, plugged and set the NS4 Hypermux on it to see if it works better than my modulator and it's perfect .
    I will improve it carefully later ...
    Pictures of this IRD:
    And some menus
    (ADV6000S) Streaming on a LAN
    I 'll built my own package on a next test
    More test of this IRD
    using the Remux option, which is perfect to select one or any you want) to broadcast over your LAN or SDI / ASI output (FTA or BISS)
    Finally I found the appropriate Cband LNB holder kit and arms for the 2.40m, better than my "home made arms"
    And it perfectly match with original Feedhorn
    next step: motorized this antenna
    Christmas before the hour here
    maybe you don't know what is this but this is just a matrix, I wll be able 8 in / 8 out with a simple interface.
    8 antenna/lnbs to 8 appliances,card, demodulator , etc
    Exactly what I wanted, and 13/18 22Khz capable
    not cheap but very interesting.
    just unpacked
    more photos to comes
    After an afternoon spent in the middle of a forest of cables :401: I have rethink my "DX room" and especially my DX center , now based on the DEV1982 8X8 has the master to manage my satellites stuff
    Te preset are not terminated yet,
    I have attached the SSA spectrum analyser to the SMA output, it works well
    few screenshots :
    PS: I am still having 2 "U "available in my bay, maybe another Christmas present will follow ? I have send my letter :79:
    Here is un updated diagram of my installation:
    "I´m in heaven..." :31:
    Thanks Feedsat for sharing with us!
    C-band: 55.5°West-68.5°East ORBITRON O-16 (4,9m) / X-band: 17.8°W-60.2°E KATHREIN CAS 120 (1,2m) / Ku-band: 61.0°West-80.0°East KATHREIN CAS 23 (2,2m)
    Ka-band A/B/C/D: 30.0°W-75.0°E KATHREIN CAS 018 (1,8m) / Ka-band band A 2x KATHREIN CAS 120 fix on 19.2°E and 42.0°E
    C-band LNBs: Kaonsat, C-Panorama 13K, Norsat 8000RI C-DRO, BrasilSat LNBF AP30 PLL / X-band LNB: Norsat X1000HAF / Ku-band LNB: Invacom SNF-031, Inverto Single Flange / Ka-Band LNBs: Inverto Twin WHITE Ka Circular Dual Polarity LNB (flange), Inverto IDLK-SINL20-KAKU-OPP,MCL-KP04, Norsat 9000HX-O3B-BN, Orbital LNB1825F-1000D-WF55
    Feeds: Invacom ADF_10 + 2 rings, XMW Ka-band Feed FD9000K / Waveguide Polariser: AV-COMM / Tuner: TBS 6925, TBS 6903, TBS 6903X, TBS 6522
    OK, here is the latest Toy which has join the "DX room"
    Few screenshot of the menu, test will be done during the next days.
