Unknown type streams
  • Hi,
    known type use BR (Bayern Rundfunk) on Eutelsat 7B - 12537 V ?
    maybe for DAB ?
    2 Mal editiert, zuletzt von EnoSat ()
  • Hi Eno,
    it must be the BR DAB Mux distributed on Channel 11D in Bavaria.
    Please tell me if you find more of these.
    What are the exact tuning parameters. I cannot get a lock on this frequency. :(
    I think it´s this one.
  • Bilder
  • There is one big MPE mux with multiple DAB EDI streams on Eutelsat 7°E containing 5 BR muxes plus SWR S mux.
    In linux we are already able to decode those muxes using Piratfm's tool https://github.com/piratfm/eti-tools
    There's also a list of already found DAB distribution feeds.
    I guess there are more around, but finding them needs analysis with Hex Editor.
    EnoSat: Did you try IPCleaner.exe for Mxf?
  • today
    JurassicWorld2_FTR-9-3D_S_EN-es_ES-TD_51-Dbox_0516_02.mxf CLN_COMBI_V2 _3D_51-71-DBOX_IOP_UP_ASSCLN_COMBI_V2\JurassicWorld2_FTR-9-3D_S_EG N-es_ES-TD_51-Dbox_0516_02.mxf
    on 5W_11551H
    result in MediaInfo after extract in OTTextractor:
    C:\Users\Public\Downloads\OTT\11551_200_125.2.ts
    Formát : MXF
    Velkost súboru : 584 MiB
    IsTruncated : Yes
    FileExtension_Invalid : mxf
    Video
    Formát : JPEG 2000
    Profil formátu : D-Cinema 2k
    Šírka : 2 048 pixelov
    Výška : 858 pixelov
    Pomer strán : 2,40:1
    ColorSpace : XYZ
    ChromaSubsampling/String : 4 : 4 : 4
    BitDepth/String : 12 bitov
    result in MediaInfo after IPcleaner:
    C:\Users\Public\Downloads\OTT\11551_00C8_sub001.ts
    Formát : MXF
    Velkost súboru : 595 MiB
    IsTruncated : Yes
    Video
    Formát : JPEG 2000
    Výška : 858 pixelov
    ColorSpace : XYZ
    7 Mal editiert, zuletzt von EnoSat ()
  • I guess you have to record the mxf file from.the beginning. Unlike TS where header information is repeated regularly, this is not the case for mxf.
    Do you know other mxf feeds as well?
  • Zitat
    Original von newsy
    momentary no (maybe feeds for theatre/cinema)
    PS:
    next interesant on 5 West - 11450H
    two stream in one TS
  • Zitat
    Original von EnoSat
    Finally I'm able to deprocess this stream using a DigitalDevices CineS2 V7a.
    It's GSE with 2 UDP multicast streams. These streams contain a TS each. One is skytg24, the other one was a Testcard when I checked last time.
    I will publish a GSE decoder when I finished it, ATM only a sunset is implemented to decode this mux.
    If you know more streams like this please tell me.
  • 4.9e 11682 V 28000
    That one doesnt look like a test carrier, it seems like there is some content, any ideas what it could be? T2-MI?
    update: my bad correct freq is 11862 v 28000
    Original von VodzigorLans
    4.9e 11682 V 28000
    I can´t see this signal from my place. :125:
    Okay, but I cannot analyze this stream more precisize... :79:
    From my point of view and after a deep analyse, this is just a DATA mux with 2 IP .
    No A or V PIDs found , but I am probably not the best expert
  • in booth stream more use string "SFN"
  • and test MPE on 13E/12577H ?
    http://enosat.euweb.cz/dvbip.htm
    According to the PIDs Rate, it's a TXP on test in my opinion
    with 99.87 % of nothing...
