Hi,
known type use BR (Bayern Rundfunk) on Eutelsat 7B - 12537 V ?
maybe for DAB ?
Unknown type streams
Hi Eno,
it must be the BR DAB Mux distributed on Channel 11D in Bavaria.
Please tell me if you find more of these.
What are the exact tuning parameters. I cannot get a lock on this frequency. :( -
I think it´s this one.
thank you very much qwer.
Seems like I've got a hw problem, I can't rotate my dish atm. :( -
5 West - 11634 H DVB-S2/8PSK - pid 0x0578
There is one big MPE mux with multiple DAB EDI streams on Eutelsat 7°E containing 5 BR muxes plus SWR S mux.
In linux we are already able to decode those muxes using Piratfm's tool https://github.com/piratfm/eti-tools
There's also a list of already found DAB distribution feeds.
I guess there are more around, but finding them needs analysis with Hex Editor.EnoSat: Did you try IPCleaner.exe for Mxf?
Original von newsy
There is one big MPE mux with multiple DAB EDI streams on Eutelsat 7°E containing 5 BR muxes plus SWR S mux.In linux we are already able to decode those muxes using Piratfm's tool https://github.com/piratfm/eti-tools
today
JurassicWorld2_FTR-9-3D_S_EN-es_ES-TD_51-Dbox_0516_02.mxf CLN_COMBI_V2 _3D_51-71-DBOX_IOP_UP_ASSCLN_COMBI_V2\JurassicWorld2_FTR-9-3D_S_EG N-es_ES-TD_51-Dbox_0516_02.mxfon 5W_11551H
result in MediaInfo after extract in OTTextractor:
C:\Users\Public\Downloads\OTT\11551_200_125.2.ts
Formát : MXF
Velkost súboru : 584 MiB
IsTruncated : Yes
FileExtension_Invalid : mxfVideo
Formát : JPEG 2000
Profil formátu : D-Cinema 2k
Šírka : 2 048 pixelov
Výška : 858 pixelov
Pomer strán : 2,40:1
ColorSpace : XYZ
ChromaSubsampling/String : 4 : 4 : 4
BitDepth/String : 12 bitovresult in MediaInfo after IPcleaner:
C:\Users\Public\Downloads\OTT\11551_00C8_sub001.ts
Formát : MXF
Velkost súboru : 595 MiB
IsTruncated : Yes
Formát : JPEG 2000
Výška : 858 pixelov
ColorSpace : XYZ
BitDepth/String : 12 bitov -
I guess you have to record the mxf file from.the beginning. Unlike TS where header information is repeated regularly, this is not the case for mxf.
Do you know other mxf feeds as well?
Original von newsy
I guess you have to record the mxf file from.the beginning. Unlike TS where header information is repeated regularly, this is not the case for mxf.Do you know other mxf feeds as well?
momentary no (maybe feeds for theatre/cinema)
PS:
next interesant on 5 West - 11450H
two stream in one TS -
Original von EnoSat
Finally I'm able to deprocess this stream using a DigitalDevices CineS2 V7a.It's GSE with 2 UDP multicast streams. These streams contain a TS each. One is skytg24, the other one was a Testcard when I checked last time.
I will publish a GSE decoder when I finished it, ATM only a sunset is implemented to decode this mux.
If you know more streams like this please tell me. -
4.9e 11682 V 28000
That one doesnt look like a test carrier, it seems like there is some content, any ideas what it could be? T2-MI?update: my bad correct freq is 11862 v 28000
Original von VodzigorLans
4.9e 11682 V 28000
That one doesnt look like a test carrier, it seems like there is some content, any ideas what it could be? T2-MI?I can´t see this signal from my place.
I am sorry, it is 11862 V 28000
Okay, but I cannot analyze this stream more precisize...
From my point of view and after a deep analyse, this is just a DATA mux with 2 IP .
No A or V PIDs found , but I am probably not the best expert
in booth stream more use string "SFN"
Original von newsy
and test MPE on 13E/12577H ?
http://enosat.euweb.cz/dvbip.htm -
NIT: 4.9E 11.785 GHz Vertical 22000 5/6 8PSK
Network Name: TV PlayWhat do you think it is just some test for Viasat SD to HD switch or some kind of ip tv service?
According to the PIDs Rate, it's a TXP on test in my opinion
with 99.87 % of nothing... -
some digital sound with RDS data
