53.0°E Express-AM6
  • The two PLP packages (12674 and 12694V) from Yamal 402-54.9E will move to Express AM6-53E.Have already started to transmit with the same parameters and streams(PLPs) with the same channels on two different transponders.
    12591 H,14990,3/4,Dvb-S2/8PSK,CCM,PLP:0,1,2
    12611 H,15286,3/4,Dvb-S2/8PSK,CCM,PLP:0.1
    Thanks!
    I think now, the PLP packages are on fixed beam 1 (Russia), while 12657 H is on fixed beam 2 (Europe/ME).
    Different transponders, and each can be switched to a different beam.
  • Zitat
    Original von hvdh
    I have no signal satesco, are these PLP packages still there?
    pawelwa answered in my place.Thanks :72:
    And yet here is the signal in my area today on the two PLP transponders and also on high band:
  • 12596 H,15284,3/4,8PSK-T2-MI_it's still active atm
    12576 H(T2-MI) has left.
    hvdh: moved to correct topic. Please, no bitching :83:
  • 15278H DVB-S2/8PSK SR-14185 FEC-3/4
    12595H DVB-S2/8PSK SR-14185 FEC-3/4
    12614H DVB-S2/8PSK SR-16410 FEC-3/4
  • My try on T2packets, only 12674H on the limit (better FEC) .
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
  • The upper band in my area with Crazyscan and IQmonitor.
  • Much-esteemed satesco !
    I appeal to you again in order to supervise the IQmonitor Pro program
    In my last appeal to you, I pointed out the fact that your choice of the wrong ratio of the parameters for visualizing the RF spectra greatly distorts them, unnecessarily compressing the dynamic range of the output. The spectra become inexpressive and, in comparison with other programs, make a depressing impression. This undeservedly discredits not only the program, but also its author.
    I urged you to ask
    Min level RF <= Noise level
    but by no means the other way around.
    You again set Min level RF = -45dBm , and Noise level = -50dBm.
    This narrowed the dynamic range of the signals by 5dB and gave the false impression that IQmonitor Pro had worse sensitivity than the reference program.
    In fact, the SNR of the signals that IQmonitor Pro detected is in most cases 1-2 dB higher, and at a frequency of 12719 MHz it is 3.4 dB higher.
    I really hope that you will heed my urgent request for the choice of these parameters.
    Otherwise, I will be forced to blacklist you in the IQmonitor Pro program.
    Health and success :74:
  • 12674 H,16804,2/3,8PSK-RTRS Krym_3 Radio and PLP 0(Eduard on FlySat)
    /merged in T2-Mi section by qwer
  • Today locked TP 12576 H , works on the limit , 8db.(12674 H 8db too)
    TBS 6983
  • 11463 H 14182 1/2 QPSK2 atm. probably testing, cant make T2 analyze,TS reader crashes, another 2 TPs are off.
    Edit: Hacked by Ukraine?
    TBS 6983
  • Well,it was really hacked , atm there are 3 original T2 TPs.
    TBS 6983
  • Edit: Hacked by Ukraine?
    :51:
