Posts by superdish66
Down here you can find the full changelogs from 10.0.0 to 10.1.0. Regards to all of you. Superdish66
**TBS Universal 10.1.0** · Signal Analyzer 6.4.0 · Core SW 3.80 · Core HW 3.80 · Superdish Mosaic engine 6.6.0
**In short.** A month of hard work on the scan engines and the two cores: hundreds of cases found in the field and closed, one fix at a time, measure first then fix. Nothing is lost — every energy seen that doesn't lock comes out as a measured row.
**File by file, what matters**
- **TBS Universal (10.0.0 → 10.1.0).** The heart of the work. Over a hundred versions, each one a real case: the ghost judge (a wide full-scale row that is only the energy-sum of its neighbours makes no row — the spectrum decides), the blue "real carrier that won't lock" note, the zones, the scraping, the cluster, the flanks and skirts of the wide carriers, the wide empty. The 18W round taken whole, from the very narrow SR83 to the sub-zero marginals. One hand on the card, never two threads in the DLL. Table Search integrated. Stop-crash closed. Import from a previous version.
- **Signal Analyzer (6.2.0 → 6.4.0).** The deep dive on a known frequency: you tune it and dig it out, even below SR 100. Batch tune of the selected ones, PLS from a preset, first true MIS. No double window. DAB watchdog so nothing is lost on the PC, bruteforce always from ROOT, faster.
- **Core SW (3.74 → 3.80) and Core HW (3.69 → 3.80).** One hand on the DLL, a single lock that lines up the methods that touch the card. UDP fix (10054), robust T2-MI read, and the two cores kept byte-identical except the capture machine.
- **Mosaic engine (6.5.0 → 6.6.0).** Robust open, no lockouts, all the options already set, CPU and GPU fine.
- **Table Search and DAB.** Ready for release and verified: Table Search comes with its per-satellite feed profiles, DAB with its chain. Separate modules, they don't follow the TBS Universal numbering.
**Scan types, in brief.** List/FINE (the base pass, 2 MHz windows), FULL (full blind scan), PEAK (the peaks), Span (FULL or FINE over the box, without clearing), BLScanEx (≥500 kHz, RF in C-Band too), Total scraping (the gaps between two locks, a long pass, off by default), Hot zones (the most efficient phase), Low SR exp, Listen after the no, Hammer, Cluster (the weak very-narrow carriers, only on span and FINE), Look (the in-depth read of a row).
**Install and import.** The folder is clean, for a new installation. You install, then from inside the program you use "import from a previous version": it merges your data without overwriting and backs up before touching anything. Marks (segni) are each user's own, copy yours over from the old installation.
**The changelog.** The full changelog, file by file, is in the package. It's worth reading in full: a lot of what was done isn't visible until you know it's there.
**The work continues.** On perfecting the scans, on the Deep Analyzer (the new PantaReader) and on the mosaic. NIP stays under revision, decoupled from the stability of this release. The heart of the program is everything else, and it stays solid.
**The vision.** We don't copy the lists everyone consults: we measure the live mux. Frequency, polarity, input stream, PLS are what the card reads, not what the provider declares.
**Your tests.** Above all, reports with logs. We don't fill the post with screenshots, the discovery is the best part: post your captures, your tests and your diaries below.
**At your disposal.** For any explanation on the functions and the specifications, just ask.
**Thanks.** To the collaborators you'll find in the "?": stephan94 , satesco , femi , danluc , Cirio70 , and to PantaSat for the tests and the card study. Without your field measurements, on satellites and bands I can't test myself, this release wouldn't exist. You can check previous posts PantaSat
Superdish66
https://www.mediafire.com/file/4v1f5irm6….1.0_1.zip/fileIn the photos last full deep Test on 18W KU Band with v. 10.1.0 - Location: North West Italy - 4.2Mt Dish - TBS 6908 - 6983 - 5927
A quick preview of what the next update brings.
On 18.0W, between 11689 and 11691 H, there is a group of narrow DVB-S2 carriers, all carrying Irish radios. TBS Universal catches them on the spectrum, and the Superdish Mosaic plays them. One of them sits below 100 kS/s — exactly SR 83 — and for Those ones there is a dedicated tool. Point by point.
**The spectrum draws the narrow carriers, and a double-click looks deeper.** TBS Universal puts the carriers on the spectrum and catches them down to around 100 kS/s; a double-click on one starts the in-depth search on that exact point.
**DEEP CATCH, for the one below 100 kS/s — here the SR 83.** From Direct Tune you give it the frequency and press DEEP CATCH. From there it works by itself: the symbol rate, the modulation, the FEC and the SNR scroll live on the panel while it warms the point — you watch them move. When the carrier comes up, it locks. You do not type the values in first; it reads them for you.
**Catching the sub-100 kS/s carrier directly on the spectrum is what we are working on now.** For the moment the SR 83 is reached with the DEEP CATCH above; the automatic catch on the spectrum is the next step.
**And they play — in the Superdish Mosaic. This is the part that counts.** Once a carrier is locked, the Superdish Mosaic opens the whole mux and plays it: a radio-only mux opens as radio, every station at once, one clean cell each, in a single window — the SR 83 included. You do not only see the carrier on the spectrum, you hear it. Measured on today's run: no dropped packets, clean sound throughout.
**The LNB holds on these frequencies.** On these narrow carriers the lock stays steady over long runs — today the SR 83 locked and held. This is the point: without a steady LNB a sub-100 kS/s carrier does not hold, and nothing would play so long (signal goes up and down).
We do not copy the lists. We measure the live mux: if the energy is there, we find it, we lock it, and we make it play — and we play it in the Superdish Mosaic. Ready in the coming update.
Superdish66
Spirit Radio Ireland with EBS PRO and Potplayer stable from here SINCE 1h 30MINS, North West Italy 4.2MT TBS 6908
11689,363 H 83 DVB-S2 QPSK 8/9
And from now .. with TBSU - Sygnal Analizer and Superdish Mosaic Engine
My Test from North West Italy with TBSU and Superdish Mosaic Engine - 4.2Mt Dish - TBS 6908 - in H
Same test in V with TBS 5927
One low SR Freq. appeared: 11546.226 V 359 . Tried neighbor 15W but nothing. It should be real, not Ghost Freq. (too low SR) and not Blue Line for the same reason. Maybe, other neighbors or real new Freq. (possible Low SR Radio)
**Blind scan: ghosts and blue carriers (coming in the next version)**
The next version adds a measurement step that separates a false wide reading from a real carrier the card cannot lock. In short:
**Ghosts**
- **A ghost is summed energy, not a carrier.** On a blind scan a wide reading sometimes appears with no lock, SNR at the estimator's floor, and a strange, high symbol rate.
- **It sits between two real carriers.** The reading lands in the valley where the shoulders of two carriers add up, and its apparent symbol rate spans the gap between them.
- **It is not specific to one program.** The same summed-energy reading shows up in other blind-scan tools (CrazyScan, EBSpro): it comes from the measurement, not from the software.
- **Geometry only raises the suspicion.** Two carriers of the same polarity cannot share the same space, so a wide floor reading whose band covers a carrier that does lock, frames a pair of real ones, or contains a narrower solid one, becomes a candidate.
- **The spectrum decides the cancellation.** The row is removed only when the spectrum measures its band empty — floor at the 20th percentile, a point counted as full at 3 dB above it, fewer than half the band's points full. Geometry alone never removes anything.**Blue carriers**
- **Blue is a real carrier the card cannot lock.** A high MODCOD (DVB-S2/S2X) or a marginal DVB-S near threshold shows no lock and SNR at the floor, at first glance identical to a ghost.
- **The same formula tells them apart.** A real carrier fills its own band (more than half its points full); a ghost's band is mostly empty.
- **A blue carrier is never cancelled.** Removal needs both the geometry and the measured void, and a carrier that fills its band fails the void test, so the measurement always overrules the suspicion.
- **This morning, in the field.** 8W horizontal: two DVB-S carriers came in at -10 dB with the correct symbol rate; the spectrum measured their bands 98% and 59% full, and both were kept and coloured blue. The DVB-S2 carriers beside them had a real measured SNR, so they were never candidates, just ordinary no-lock rows.We do not trust the lock bit. We measure the energy.
Superdish66
Example of Blue Carriers on 8W in Low Band Pol. H - Middle East Beam from North West Italy, 4.2Mt dish - TBS 6908
My deep night Test from North West Italy with TBSU and Superdish Mosaic Engine - 4.2Mt Dish - TBS 6908 - in H
Not possibile low band at this time from here except
10727 H 27500 DVB-S QPSK 7/8
Same test in V polarization low band. Using: TBS 5927
DVB-S Freq are receivable from here morning time
11804 H 30000 DVB-S2 8PSK 3/4 - Not possible form Here (Recently changed from QPSK)
Same test in V polarization. Using: TBS 6983
Signal is very weak from here at this time.
Freq. 11747 V 27500 DVB-S QPSK 5/6, 11938 V 30000 DVB-S QPSK 5/6, have not been intercepted
Freq. 11823 V 27500 DVB-S QPSK 5/6, 11977 V 27500 DVB-S QPSK 5/6, locked at -10dB
Same test in V polarization. Using: TBS 6983 for High Band, TBS 5927 for Low Band
Including NWA Beam Freq. 11158 V 5000 DVB-S2 8PSK 9/10, 11227 V 41663 DVB-S2 8PSK 3/4 (3 Data Ch.)
Other Freq. from 11450 to 11700 in V not possible due to high power of 5°West hiding them in my area
Happy birthday to our Boss qwer
