Posts by moonbase
    I see an even bigger problem: you have all the parts and no one is helping you with the assembly. With a large antenna, especially a full-diaphragm one, you simply need help.
    Yes, it took 4 of us to get the dish mounted on the stand, it might have been possible with three people but with four it was safer.
    These dishes are not for dreamers who think they want a big dish but have no experience or knowledge about what is required to install one.
    Could anyone please help me with some advice?
    Using VMA Ultimate Stream Reader on 7.0E in H-POL there are a few frequencies with SR of approx 4937 that have frequencies that are near to each other. These feeds have a carrier width of about 5.9MHz each and are only 6Mhz apart.
    What values for "Linear Step (KHz)" and "BLScan Half-Range (KHz)" should I use for this type of narrow carrier width that are near to each other so that I get a clear lock on each one?
    Lastly, in one of the future updates for VMA Ultimate Stream Reader would it be possible to have the carrier width info provided in the details of the transponders found section that is located underneath the spectrum?
    Thank you
    Just to see how a TBS6903x card can cope with higher modulations I tested it at 64APSK, 64APSK_L and 128APSK using the EBU DRM frequency from 10.0E as a source. To summarise, the TBS6903x was OK with both 64APSK and 64APSK_L but it failed with 128APSK.
    Screenshots from the test are attached below, test results have no real value as they are synthetic but they show the TBS6903x failed on 128APSK within the scope of my testing. There are slight differences in the constellation diagrams, not a lot but some small differences between 64APSK and 64APSK_L.
    64APSK
    64APSK_L
    I am trying to send some FTA channels from the VMA Ultimate StreamReader to VMA Transport Stream Analyser then to VMA Mosaic but the windows in the mosaic are all black with no pictures.
    I know the channels are FTA and currently have pictures. I am using a dedicated GPU (GTX 980Ti) in an i7-12700k CPU based PC with 32gb of RAM. There is certainly enough PC power to render three windows in a mosaic.
    Any help most appreciated.
    Has anyone noticed a difference in the bit rate reported by Ultimate StreamReader va CrazyScan or EBSPro?
    I have pasted below 3 pictures where the 7E frequency of 11070H bit rate is listed.
    Ultimate StreamReader bit rate = 14.536mbps, CrazyScan = 12.179mbps, EBSPro = 12.211. Ultmate Streamreader seems to be reporting the bit rate higher than the other two apps from the same 6903x card using the same input tuner?.
    femi
    I am not sure what you mean by calibrating the LNB with the respective oscillator? Could you please give more details on how i do this? I checked the known frequency of a carrier with the frequency that was scanned by the VMA Ultimate Streamreader app in FFT mode and the gap was only 0.2MHz
    Hello,
    The best way to use the software is to put VMA StreamReader CLI in a dedicated folder and create a Scheduled Task, so that it is automatically started with your login. This way you can forget about it and used it via telnet 127.0.0.1 8888 (or whatever IP/Port you defined).
    And yes, I removed the tbs6903x_blindscan.py because it became obsolete: this is the script the evolved to VMA Ultimate Stream Reader.
    Finally, a clarification: "Do both apps offer identical functionality for my planned testing?"
    No! They are totally different applications:
    • VMA StreamReader CLI is a front-end for streamreader.dll. It can be used with command line arguments (including simple scripting with FOR-NEXT loops) or via telnet, which allows complex scripts to be created.
    • VMA Ultimate Stream Reader is a Python application that connects via telnet with VMA StreamReader CLI and implements a complete fully featured DVB-S/S2/T/T2/C/C2 tuner application.
    Both apps are free to use.
    Thank you for your reply and all of your help so far, most appreciated. I tried the task scheduler method and got an error message when I tested it with telnet 127.0.0.1 8888 in a cmd box. I was not sure about what to put in the "Start In" box in the task scheduler? Would anyone please be able to share a screenshot of their task scheduler configuration for VMA please ?
    I got the VMA Ultimate version to work by manually starting the server then double clicking the *.exe file. This opened up the app and I was able to do a scan. I think I need to install the reportlib to be able to save scans as pdf files.
    In the Ultimate Streamreader Setup Dialogue there is a setting for "BLScan Half Range (KHz)". If I am scanning narrow carriers that might be 4MHz carrier width or less, what setting should I use for the "BLScan Half Range (KHz)" please ?
    Thank you.
    VMA
    Is there a best option for work with a TBS6903x card between Streamreader CLI and Ultimate Stream Reader please?
    For the testing I hope to do, I will be using a TBS6903x card and hope to use the FFT frequency correction feature to get accurate frequency values.
    Also, I have just noticed that the tbs6903x_blindscan.py script is missing from the most recent version of the Streamreader CLI download. Is this deliberate? This was the script I hope to use for testing with my TBS6903x card in FFT mode.
    Thank you.
    VMA
    I have a couple of questions if you can please help?
    1. Is the FFT scan frequency correction from a TBS 6903x card available in both the streamreader CLI app and the Ultimate streamreader app please?
    2. Will a TBS 6904SE card be OK for an FFT scan in both apps? The issue with this card is that it has no constellation functionality compared to a TBS 6903x card? Also, what script should be used in both apps with a TBS 6904SE card please?
    I am hoping to get a clean install of python onto a PC on Monday and get working with both apps.
