Beiträge von Afreaka
4030 L 1300 is "HK6 television", transmitting from Lubumbashi in DRC. Khaled star already reported in the Rascom-thread...but as it is in L it should be on Eutelsat. A little bit strange as the other Congo TVs are in R on Rascom.
10°East got less interesting over the last months, so I turned the antenna to 3°East. My scan (240cm, KaonSat, homemade dielectricum)
Uganda mux on 3915 R 13252 is FTA
Laut "Denic" wurde die domain "dxtv.de" am 25.7.22 gelöscht.
Same situation here. Signals are weaker since several days. I also thought there is something with the LNB and maybe I should switch to my backup LNB. But you guys seem to have the same problem. On top of that there is a lot of rain now, so super bad conditions...
Galaxie TV (from Cameroon) now with program on 21555 H
TCV now on 3876 R 1000
Both channels now with test transmissions - from Congo DRC (Kinshasa).
Now on 3830 R 2063 (8PSK 2/3) from the airport in N'Djamena for Chad television.
Look at the 2 guys in red dress from the orchestra. They are pissing just 5 minutes after welcoming the president of Burkina Faso.
3830 R 2063 was used by Télé Chad earlier last year as a feed.
Today, some african presidents arrived in the afternoon at N'Djamena. On Feb 15-16 there will be the "G5 Sahel regional summit". So I think this frequency will be more active again tomorrow.
Not sure if it´s on Rascom or 3°east, but normally Rascom has this range in R (qwer, you can move it to 3°east if you think...)
New:
4036 R 1000 8PSK 3/5 "Label TV"
4033 R 2083 QPSK 5/6 "Amen TV"
Amen TV is listed on 4029 L on 3°east, maybe changed frequency and/or satellite
Here is my TBS 5927 scan with KaKU LNB - in light snowfall and a little bit of snow in the antenna.
Eden around 12 dB, Canal 2 around 11 dB, but still no sign of Golfe TV.
Well, the guys in Cameroon fixed their antenna or finally fired up their amplifier, the Canal 2 package on 21576 H is back again with old strenght. Not tested with TBS 5927, but should be around 11,5 dB.
And the same for Benin and "Eden TV" on 21542 H, much stronger than the past months.
3986 R - no lock on the Congo package now - SR changed to 11998 ... GS now?
The Congo-package is back on with old parameters (3986 R 16296)
I'm back to C band after 3 weeks of KU.
Malaiaka & Boing still there?
I have no signal with 1.8m.
I think "Boing" on 4010 (see FS) was also Malaika, but they relayed Boing. Then, some days ago, they changed to 4016. Now I have also nothing.
Seen earlier today, but off now:
4026 R 1000 (8PSK 3/5): Bnews1 from Cameroon with testcard
Also on yesterday evening with promo-loop. Transmission will start January 15th....maybe normal transmission in the future, we´ll see.
