I think something will disappear soon that for sure :D
Posts by pipino
yes..BBC SAT-BACK users will be the most affected !!!
Here in spain , Promax is well known to work very well with this feature but its an enigma how it get the full sat info
i d love to hear from yuri regarding this matter , is SAT-ID comes thru stored data base in all 3 mentioned meters or is there another way to get the info from each satellite ???
so whats is special about Promax or Televes ?? they can scan any sat and get the name and position data of any Sat
Hello , there is also another meter with the SAT-ID capability --->
, i looked everywhere on the net i couldnt find anything regarding this feature !External Content youtu.beContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
Hello everyone,
I am doing a research about SAT-ID (the one used in meters like Promax or Televes ) I couldn't find anything about it !!, how does it work?? is there a special data on streams like a digital signature or a beacon transmitting the data for each satellite?? really appreciate your help
looks like the russians T2MI services in this Satellite left ..
indeed there is something, !!! i did a very quick check using a TBS5930
i will check it for you shortly at my location (Southeast of Spain)
may be interference in your local area ?? I had something similar once on Eutelsat 5W, can you see content thru stream analysis???
new puzzle on TP 10922 V 16400 !!!!, is Cellnex (Abertis) using something new there ??
channels went from that frequency. I think it was a test !!
Hello satom ,
impressive setup !! thank you for sharing with us..where are you located ?? are you still using invacom quatro LNB for your tests???
Hello ,
very strange your reading i have the same transponder with different tables ?? ..please see my post further up, this is a real mystery transponder and its using Biss key on PMT exactly like Abertis , wonder if the key is public somewhere
dish needed a fine tune ..all 3 transponders ok now !
Hi,
are they still all active??
i only see :11646 V,14182,3/4
iv posted the TS file ..inside i saw couple intesting PIDs with MPE data , pid 1600 specialy
looks like a TV channel , the weight is 4.5 mb/s
ts file : https://ufile.io/7qlbr8p6
