Posts by Fidu
Today, because of the cold weather I can receive Nilesat 201 Transponder 12148 H 27500 3/4. Transponder 12226 H 27500 5/6 can be found in Blindscan.
To compare, Tranponder 12303 H 27500 5/6 from Nilesat 301 has here at the moment 7 dB.
Greetings
Here in Central Switzerland I can still receive Subsahara Africa Beam. All Transponder with dvb-s are still there but the signal is in average about 1,5 dB weaker than before.
Hi Qwer
My Antenna will be back on Balcony only in September. I cant test earlier.
Sorry
Fidu
Bei mir in der Zentralschweiz ist mit der Gibertini 125 im Highband und im Lowband vom Eutelsat 8 West B absolut nichts zu sehen.
qwer:
12015 V is completely gone since this afternoon at my place. Maybe back to Nilesat 201? Best reception here for Nilesat 301 is early evening.
Greetings
Fidu
I can receive now 12015 V 27500 DVB-S 5/6. It seems to be Nilesat 301. Signal with Gibertini 125 and Extension + 16 cm is about 6 dB here in Dagmersellen, Switzerland.
At the moment signal here is slightly better and I am able to see 12054 v also. Signal is still 0,5 dB better for 12303 h
12054 V is about 0,5 db weaker than 12303 H.
In comparison wirh Nilesat 201 about 2 dB more here from 301.
Hi
12303 H is receivable but very weak here in Dagmersellen, Switzerland with Giberini 125 cm Antenna at about 9 pm.
Hallo zusammen
Mit dem Octagon sf 8008 sind momentan alle Sender zu sehen. Antennengrösse ca 165 cm
I have made a scan (my location is central Switzerland) from subsahara Beam. Antenna is a Gibertini 125 cm with some provisorical panels, its now about 145 cm. I can get 12 Transponders. If I see it right in my Scan, there is also a small sign from Eutelsat 36C transponders?
Greetings
Fidu -
Thank you for checking on it, I thought it has maybe allready left this position like all the other channels.
Have a nice evening
Fidu
Has GRTS Gambia on 4054 RZ also left this position? As I cant find it anymore since a few days. I have checked on Intelsat 37 but it seems not to be there or very weak. Maybe someone with a bigger dish can find out more?
Greetings
Fidu
Thanks, so thats the reason I got only errors when I tried to read the stream with enigma2. Lets hope it will come
back. -
Again on old parameters 3676 RZ 28070, but very strong signal. 150 cm Antenna should be enough now.
Greetings
Fidu
