Yes as we have that same "service" on 172E Eutelsat KU band so it was tested on the same signal format there
Posts by Apsattv
Post more screenshots
A friend is building a great new tool
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
Yes sorry i missread it
Actually I might run Claude over it and see if tsreader simply uses a script for the mosaic function. It may be easy to get it compatible with the current versions of vlc
Paid for tsreader pro many years ago.
Nobody should be installing a 15 year old version of VLC, that is completely insecure. I would suggest you need to make adjustments to lose that requirement.
Perhaps then he should publish it through GIthub? and that would allow people to contribute to adjusting the code?
To make things a bit easier to work with , can you focus on getting the user interface completely into English.
Along with doing a single archive that includes ALL parts of the package with a "Check for updates" function.
I found the "Suite Control Center" a bit of a confusing mess as the frontend to integrate everything.
I just downloaded your software package. I look forward to seeing it translated into ENGLISH
Hi thanks for the files someone is studying them now.
Can you record both?
7288 L 5048 2/3 DVB-S2 8PSK - new
7478 L 5048 2/3 DVB-S2 8PSK - newa few hundred MB or even up to 1GB each??
and upload them somewhere?
I wonder if any of the tbs cards have potential to be "overclocked"
confirmed feed there now
Apstar 7 3979 V Sr 7200 Fec 2/3 "NZ Tour of Bangladesh 2026"
BISS Encrypted -
There was also report of
Apstar 7 3980 v 7200
Feed
Bangladesh-A vs NZ-A Cricket. Being Played in BangladeshIll check there later today as it will be day 2 of the match and see if loads
Perhaps since its using VLC lib , de-interlacing mode may be on Auto by default. It looks like de-interlacing to me.
