Satellites Community » Dish setup » Introduce yourself » Paraclipse 3.8 on H to H mount restoration/installation » Hallo Gast [anmelden|registrieren]
Seiten (2): « vorherige 1 [2] Neues Thema erstellen Antwort erstellen
paradxer
Board Addict
Hi a bit more progress made today pole cap adapter,
I thought i had some tubing for the job in hand but it wasn't suitable so Ive had to make do with what i have, its not the best bit of fabrication ive ever done but it works as it should,
Ive made it so it can be removed as the tube is also part of the telescopic mechanism.
Dateiname: 20181230_115958.jpg
Dateigröße: 234.74 KB
Dateiname: 20181230_132007.jpg
Dateigröße: 294.90 KB
Dateiname: 20181230_134737.jpg
Dateigröße: 255.90 KB
Dateiname: 20181230_135541.jpg
Dateigröße: 281.39 KB
Dateiname: 20181230_140644.jpg
Dateigröße: 237.57 KB
Dateiname: 20181230_140654.jpg
Dateigröße: 187.08 KB
Channel master 1.2 Freesat V7 TBS 5925
A few dishes not in use at the moment, Channel master 1.0 1.2 1.8 Precision 90cm Paraclipse 3.8, various other receivers dish movers feedhorns etc.
30 Dec, 2018 19:40 11 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Another job was designing a mechanism for fine tuning the dish round the pole we all know how tricky it can be on smaller dishes this design should make life easier on the installation,
This part wont be fixed until the dish is in ball park position.
Dateiname: DSC_0147.jpg
Dateigröße: 214.89 KB
Dateiname: DSC_0148.jpg
Dateigröße: 172.16 KB
30 Dec, 2018 19:53 58 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Zitat:
Original von paradxer
Hi a friend has been asking questions regarding this modification so i will document it in more detail,
Nothings is set in stone when fabricating and there is lots of different ways to make this design work but this is how ive done it,
Basically ive drilled and tapped the pole cap to accept the chain this pole cap is aluminum if it was steel i might have welded it on are wrapped the chain all the way round and secured it with a nut and bolt,
Then all i had to do is weld a bolt to the sprocket and bolt it all together pictures say a thousand words.
Dateiname: 20181231_134823.jpg
Dateigröße: 120.03 KB
Dateiname: 20181231_135344.jpg
Dateigröße: 225.36 KB
Dateiname: 20181231_144649.jpg
Dateigröße: 199.45 KB
Dateiname: 20181231_163131.jpg
Dateigröße: 151.31 KB
Dateiname: 20181231_163955.jpg
Dateigröße: 86.27 KB
Dateiname: 20181231_164118.jpg
Dateigröße: 167.13 KB
31 Dec, 2018 18:24 28 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi more work on this project today first job was welding some support stays onto the movable base there was a little twist in the main king post that holds it all together, the stays have resolved this issue,
Next job was fabricating a bracket for one of the winches and installing it i need to fabricate some pulleys next then the telescopic king post can be installed.
Dateiname: DSC_0155.bak.jpg
Dateigröße: 411.91 KB
Dateiname: DSC_0154.jpg
Dateigröße: 308.87 KB
Dateiname: DSC_0160.jpg
Dateigröße: 221.14 KB
Dateiname: DSC_0166.jpg
Dateigröße: 189.42 KB
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von paradxer am 01 Jan, 2019 19:56 15.
01 Jan, 2019 19:49 23 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi today's job was locating nuts bolts and washers i managed to find a PDF file with the sizes listed,
The dish mesh is usually held onto the dish by a clip called a J clip these will be replaced with tie wraps,
Then i spent half hour bolting four sections loosely on the hub i wont fully tighten anything until its all together getting the dish in perfect shape is very important for KU band at a later date the mesh will be replace with smaller hole type.
Dateiname: 1.png
Dateigröße: 118.91 KB
Dateiname: 2.png
Dateigröße: 127.99 KB
Dateiname: 3.png
Dateigröße: 276.04 KB
Dateiname: DSC_0167.jpg
Dateigröße: 198.68 KB
Dateiname: 4.png
Dateigröße: 281.09 KB
Dateiname: DSC_0172.jpg
Dateigröße: 241.85 KB
Dateiname: DSC_0173.jpg
Dateigröße: 296.93 KB
Dateiname: 4.png
02 Jan, 2019 17:49 13 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi today's progress, first job was cutting and re welding (winch no 1) arm as it was snagging on the telescopic part,
Next job was beefing up the leveling system by welding extra plates on to it,
Next job was fabricating a pulling eye for (winch no 2) then i moved onto modifying a wheel into a pulley, winch and pulley need installing that's my first job tomorrow.
Dateiname: 1.jpg
Dateigröße: 184.31 KB
Dateiname: 2.jpg
Dateigröße: 131.45 KB
Dateiname: 3.jpg
Dateigröße: 269.14 KB
Dateiname: 3.jpg
Dateiname: 4.jpg
Dateigröße: 107.37 KB
Dateiname: 6.jpg
Dateigröße: 135.71 KB
Dateiname: 7.jpg
Dateigröße: 177.33 KB
Dateiname: 8.jpg
Dateigröße: 257.83 KB
Dateiname: 5.jpg
Dateigröße: 123.79 KB
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von paradxer am 03 Jan, 2019 18:54 17.
03 Jan, 2019 18:51 56 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi today's update, pulley and winch installed and tested it works great very pleased with it.
Dateiname: DSC_0190.jpg
Dateigröße: 271.74 KB
Dateiname: DSC_0191.jpg
Dateigröße: 246.33 KB
Dateiname: DSC_0197.jpg
Dateigröße: 260.86 KB
Dateiname: DSC_0201.jpg
Dateigröße: 199.35 KB
Dateiname: DSC_0202.jpg
Dateigröße: 203.70 KB
Dateiname: DSC_0203.jpg
Dateigröße: 170.46 KB
04 Jan, 2019 18:05 21 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi ive been cracking on with this project lots of pictures to follow, i took some video last week of how the dish is deployed and just got round to uploading it enjoy.
http://sendvid.com/rknnpe5a
10 Jan, 2019 13:30 24 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
More on this project,
Pic 1
I am very safety conscious the leveling system that also holds the main pivot is fixed with four m16 high tensile bolts i decided to add two extra all the weight is at this point so i added two more fixings,
Pic 2/3
I do not want the dish stuck up high all the time and i wanted to add more stability when the dish is at low level so two jobs in one here
Info
The box section sleeve is concreted 3ft in the ground the pulley is to stop the winch wire from snagging when sleeved into the telescopic box section part,
The bottom of the Dish is approximately 3ft from the floor when lowered and raises to approximately 7ft 19/20ft to the top of the dish
pic 4
The movable base is now that heavy ive had to install winch no 3 for moving the dish up/down the runway, also on view is distribution box the cable coming out of the ground is fixed to a 8ft copper ground rod
pic 5
Another modified wheel turned into a pulley this is part of the telescopic mechanism.
Dateiname: 5.jpg
Dateigröße: 168.87 KB
Dateiname: 16.jpg
Dateigröße: 124.33 KB
Dateiname: 23.jpg
Dateigröße: 250.26 KB
Dateiname: 56.jpg
Dateigröße: 318.39 KB
Dateiname: 68.jpg
Dateigröße: 134.07 KB
10 Jan, 2019 20:43 56 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Another job before the install was checking the stops, on the paraclipse H to H there are no stops inside the motor, a magnet on each end of the chain ring and a circuit board sitting along side of the motor is the stops, as soon as the magnet passes under the circuit board the motor is cut dead as illustrated in the video below.
http://sendvid.com/sp4mel6q
Dateiname: DSC_0234.jpg
Dateigröße: 267.31 KB
11 Jan, 2019 15:29 30 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Another job was the elevation fixing point i wasn't happy with it two bits of aluminum stuck out maybe me being fussy as its lasted over 20yrs like this anyhow it was time for a new one and a bit of beefing up.
Dateiname: 1.jpg
Dateigröße: 266.01 KB
Dateiname: 2_(Medium).jpeg
Dateigröße: 164.37 KB
Dateiname: 3.jpg
Dateigröße: 138.53 KB
Dateiname: 4.jpg
Dateigröße: 159.64 KB
Dateiname: 5.jpg
Dateigröße: 155.89 KB
11 Jan, 2019 21:54 32 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi more video of the H to H with the ribs going on this is some motor i am very pleased with it.
http://sendvid.com/cqnfgopn
16 Jan, 2019 20:39 39 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
paradxer
Board Addict
Hi a few pictures.
Dateiname: 1.jpg
Dateigröße: 199.70 KB
Dateiname: 2.jpg
Dateigröße: 140.39 KB
Dateiname: 3.jpg
Dateigröße: 159.60 KB
Dateiname: 5.jpg
Dateigröße: 161.74 KB
Dateiname: 4.jpg
Dateigröße: 175.39 KB
17 Jan, 2019 18:54 11 paradxer ist offline Email an paradxer senden Beiträge von paradxer suchen Nehmen Sie paradxer in Ihre Freundesliste auf
secure-graphic.de Geblockte Angriffe: 5438 | prof. Blocks: 217010 | Spy-/Malware: 468
