Satellites Community » Ka-band » 20.2-21.2 GHz band C » Data>Ka C » 56.5°E Inmarsat-5 F4 or 56.8°E WGS-8 » Hallo Gast [anmelden|registrieren]
s-band
I am not sure if these signals are from Inmarsat or WGS-8 at 56.8E. There is only 0.5 degree between them from my location. There are 2 carriers, spaced at 1MHz, on 20201 and 20202MHz and a 32APSK signal, unlocked, on 20506 MHz, 32APSK, 9000, 3/4. The carriers are only 22dB C/N in 50Hz so are hard to find without an analyser. The APSK signal is well below threshold with me. All are circular polarised and were received on a linear feed.
I can not see the 20680 signal but the LNB has rolled off a long way by there.
Can anyone else get a better fix on them?
Dateiname: 56E_ish_21201-21202Circ_a.gif
Dateigröße: 16.66 KB
Dateiname: 55E_unknown_20506c_9000_32APSK.jpg
Dateigröße: 38.03 KB
1.2m Prodelin 1224 az-el +
S: Helical feed, 0.8dB NF LNA
Dieser Beitrag wurde schon 2 mal editiert, zum letzten mal von s-band am 03 May, 2018 19:03 50.
03 May, 2018 18:59 33 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
hvdh
Thanks for finding this, be it Inmarsat-5 F4 or WGS-8, that both arrived recently here. In any case, worth a new topic!
I suppose there is nothing below 20.2 GHz that would be Inmarsat only.
Surely the correct satellite will be identified sooner or later.
03 May, 2018 20:01 27 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
s-band
Zitat:
Original von hvdh
Thanks, hvdh. I cannot see the beacons that are supposed to be on Inmarsat. However, I left the dish pointing at that location and a strange signal has appeared on 19600MHz circular. There is a strong carrier with sidebands spaced at about 78.6kHz that spread +/-25MHz. The SDR only has a span of 5 MHz and the analyser does not have enough resolution so I can't show the whole thing. It can be seen on Crazyscan but makes less sense there.
As far as I can tell the new one peaks at the same point as the beacons.
Dateiname: 55E_unknown_19600C_comb.jpg
Dateigröße: 138.27 KB
03 May, 2018 20:52 39 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
hvdh
Great! The Inmarsat-5 frequency plan lists 19600 as 32 MHz gateway transponders, both LHCP and RHCP.
http://frequencyplansatellites.altervist.../Inmarsat_5.pdf
03 May, 2018 22:06 44 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
s-band
Zitat:
Original von hvdh
Interesting. I am still confused as I can't work out what the data format is since I can't see any actual data. The comb is static.
There's another Ka satellite 2 degrees west and 1 degree north of this one. It has a CW beacon at 20202.5 (needs checking) and the wide band data as attached. Expres-AM6?
Dateiname: 121.8az_15.4el.jpg
Dateigröße: 83.37 KB
Dieser Beitrag wurde schon 2 mal editiert, zum letzten mal von s-band am 03 May, 2018 23:55 01.
03 May, 2018 23:32 31 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
s-band
I tried again with the circular polariser. It was very confusing as the satellites share frequencies but on opposite polarisations. All beacons appear to be CW only.
Listed are my guesses at the satellites and their beacons. The Az-El values do not have good absolute accuracy but have reasonable relative accuracy, at least to the extent that I have the satellites in the correct position order.
@hvdh, do you find it believable?
Dateiname: Ka_beacons_56E.png
Dateigröße: 31.55 KB
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von s-band am 04 May, 2018 21:19 14.
04 May, 2018 21:14 17 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
hvdh
Hi s-band! The 53.0°E beacons above 20.2 GHz are more likely from 52.5°E Al Yah 1.
Also the Az/El relative to the other 2 positions would better fit with 52.5°E.
But the wideband (72 MHz ?) signal centered around 20075 MHz is problematic, it does not fit the Express-AM6 frequency plan, and Al Yah 1 is supposedly only military in Ka-band (band C).
Maybe Feedsat can have a look someday? 91
04 May, 2018 22:05 53 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
hvdh
On 18 July, Inmarsat-5 F4 started drifting West, and now seems to have arrived at a strange new location: 11.0°E. 88
31 Aug, 2018 19:12 44 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
hvdh
Just an update here. 72
At 56.8°E, WGS-8 was replaced by WGS-9.
(WGS-8 is at 149.8°E nowadays).
Inmarsat-5 F4 is back at 56.5°E since 20 December 2018.
10 Mar, 2019 12:00 04 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
Administrator
I locked 20205 L 9892 a moment before, but signal left a short moment later when I tried to find position... 79
Dateiname: 2019-11-03_16h48_40.png
Dateigröße: 52.04 KB
Ku-band LNB: Invacom SNF-031
03 Nov, 2019 17:53 01 qwer ist offline Email an qwer senden Homepage von qwer Beiträge von qwer suchen Nehmen Sie qwer in Ihre Freundesliste auf
Administrator
That´s a strange signal - only active for a 1/10 sec... no chance for a manual scan...
Dateiname: 2019-11-03_18h01_13.png
Dateigröße: 57.74 KB
03 Nov, 2019 19:05 14 qwer ist offline Email an qwer senden Homepage von qwer Beiträge von qwer suchen Nehmen Sie qwer in Ihre Freundesliste auf
Administrator
Testing CrazyScan Vers. 1.0.2.146 and Orbital 1825F LNB.
I can "see" up to 20600 MHz. :53:
Had to re-check soon with complete Band C LNB...
Dateiname: 2019-11-03_19h59_15.png
Dateigröße: 60.29 KB
03 Nov, 2019 21:03 28 qwer ist offline Email an qwer senden Homepage von qwer Beiträge von qwer suchen Nehmen Sie qwer in Ihre Freundesliste auf
Administrator
Again a smooth lock on 20205 L.
Dateiname: 2019-11-04_12h46_36.png
Dateigröße: 61.48 KB
04 Nov, 2019 13:59 18 qwer ist offline Email an qwer senden Homepage von qwer Beiträge von qwer suchen Nehmen Sie qwer in Ihre Freundesliste auf
Administrator
Not sure, probably from position 56.8°E:
20870 L 18202 2/3 DVB-S2 QPSK
20906 L 24788 3/4 DVB-S2 QPSK
Dateiname: 2020-05-22_20h26_45.png
Dateigröße: 77.99 KB
Dateiname: 2020-05-22_20h30_02.png
Dateigröße: 72.62 KB
Dateiname: 2020-05-22_20h32_26.png
Dateigröße: 90.11 KB
22 May, 2020 20:40 23 qwer ist offline Email an qwer senden Homepage von qwer Beiträge von qwer suchen Nehmen Sie qwer in Ihre Freundesliste auf
secure-graphic.de Geblockte Angriffe: 302518 | prof. Blocks: 217055217055217112 | Spy-/Malware: 477
