Satellites Community » Ka-band » 17.3-19.2 GHz band E/A » Data>Ka E/A » 44.1°E (incl.) Mentor4/Orion6/USA202 » Hallo Gast [anmelden|registrieren]
s-band
44.1E (incl.) Mentor4/Orion 6/USA202 Zitatantwort auf diesen Beitrag erstellen Diesen Beitrag editieren/löschen Diesen Beitrag einem Moderator melden       IP Information Zum Anfang der Seite springen
This is a strange one. I noticed a peak of noise at around 45E but at 2 degrees above the arc. My LNB is a much modified Gilat band B which does not have a flat response. The signal I get seems to cover more than 1GHz. I can see an effect from 18.2-20GHz but can not see the limits of the signal due the uneven response and bandwidth of the LNB (a much modified Gilat PLL). It appears to be circular polarisation, I was using linear.
I get around 8.5dB increase in noise at 18.7GHz. A very rough calculation based on 209dB path loss, 46dB antenna gain, 3dB noise figure and 1GHz bandwidth gives an eirp in the region of 60dBW. i.e. A lot, treat this figure with caution.
At first I though it was terrestrial noise but it peaks very clearly. If I am right it could be very wide band spread spectrum. However, since I can not see any shape to the signal, this needs more work. The TLE are getting old (13/2/18) and put Mentor 4 at 45.57E. My dish is only accurate to +/-1deg and it appears to be around 44.5E 5N at the time of the attached plot. http://www.n2yo.com/?s=33490&live=1
Since the position seems to be tracking the predictions, I feel reasonably sure it is Mentor 4 but does anyone have a system which can confirm this finding? A wide band system with flat response is ideal.
Dateiname: Mentor4.jpg
Dateigröße: 79.09 KB
1.2m Prodelin 1224 az-el +
S: Helical feed, 0.8dB NF LNA
X: 1.2dB NF LNA, conical feed
Dieser Beitrag wurde schon 3 mal editiert, zum letzten mal von s-band am 01 Apr, 2018 17:28 55.
01 Apr, 2018 17:11 49 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
hvdh
Strange indeed! UHF-satcom reported TT&C on 17810.1 MHz.
https://uhf-satcom.com/satellite-reception/ka-band
01 Apr, 2018 18:20 05 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
s-band
Zitat:
Original von hvdh
Thanks, I didn't see that. I'm not sure my modified LNB does much below 18.2GHz but I'll take a look. Using a band D I can see that it ends at 20.7GHz at the top. I can't be sure if there are any small gaps. I'm not sure that anyone would notice it unless they were using a wide band fast sweep.
Dieser Beitrag wurde schon 2 mal editiert, zum letzten mal von s-band am 01 Apr, 2018 19:08 33.
01 Apr, 2018 18:38 17 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
s-band
The LNB is not so good at 17810 but the signal is very strong. The beacon is on 17810.06MHz unless my calibration has slipped.
Edit: The 2nd plot shows the modulation on the 1st upper side band.
Edit 2: I didn't notice the other sidebands at +/-15.5MHz
The complete frequency range of the noise/signal is about 18.2 to 20.7GHz. The edges are not sharp and I can't tell if it is continuous across the spectrum but it looks like it may be.
Dateiname: Mentor_4_17810.061c.jpg
Dateigröße: 167.48 KB
Dateiname: Mentor_4_17810.061c_mod.jpg
Dateigröße: 283.75 KB
Dateiname: 17810.06_c_mentor_4.gif
Dateigröße: 4.30 KB
Dieser Beitrag wurde schon 3 mal editiert, zum letzten mal von s-band am 01 Apr, 2018 19:26 48.
01 Apr, 2018 19:07 43 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
s-band
It looks like this has been moved to ~51.5E (5.6 deg. incl) according to TLE epoch time 20/09/2019 22 : 15 : 43
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von s-band am 31 Dec, 2019 22:05 53.
31 Dec, 2019 22:05 30 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
hvdh
Hi s-band, I think you accidentally checked the Orion 6 position using the current date, instead of the epoch date?
On 20 Sep 2019, the location was about 44.1°E (in sync with Thuraya 2 at 44.0°E). Although there is no recent TLE, Orion 6 is probably still there.
01 Jan, 2020 11:50 07 hvdh ist offline Email an hvdh senden Homepage von hvdh Beiträge von hvdh suchen Nehmen Sie hvdh in Ihre Freundesliste auf
s-band
Zitat:
Original von hvdh
Many thanks for your help. Yes, it is still where you say it should be.
Here is a plot that shows the whole of the downlink more clearly. The dips at 18.2 and 18.7GHz are caused by system inaccuracies. I get some ground noise as the beam was close to trees and the roof.
Dateiname: USA202_LHCP_17.7-22.2GHz.png
Dateigröße: 64.87 KB
Dieser Beitrag wurde schon 2 mal editiert, zum letzten mal von s-band am 01 Jan, 2020 18:45 35.
01 Jan, 2020 18:42 38 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
s-band
This plot has a better SNR above 18GHz but the ripple is due to a poor VSWR somewhere in the system. It shows the sharp cut off at 20.7GHz.
3dB NF LNA with 1.2m dish
Dateiname: USA-202_9-6-20.png
Dateigröße: 78.55 KB
Dieser Beitrag wurde schon 1 mal editiert, zum letzten mal von s-band am 09 Jun, 2020 11:55 15.
09 Jun, 2020 11:39 04 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
secure-graphic.de Geblockte Angriffe: 305895 | prof. Blocks: 217055217055217113 | Spy-/Malware: 481
