Satellites Community » Extended Ku-band » Data>Extended Ku » 17.0°E Amos-17 » Hallo Gast [anmelden|registrieren]
s-band
Amos 17 Upper Ku Band Zitatantwort auf diesen Beitrag erstellen Diesen Beitrag editieren/löschen Diesen Beitrag einem Moderator melden       IP Information Zum Anfang der Seite springen
I checked 13.4-13.75GHz in February and more recently. The method of comparing a scan to clear sky noise is quite sensitive but I have not found a hint of a signal. I was using an RHCP feed so should see V & H, although 3dB down. The attached plot just shows a slight increase from the base line due to a little ground noise.
Amos 17 is supposed to have a European beam, possibly steerable, but I guess no-one has a use for it. Is there anyone further south that has seen anything?
Dateiname: Amos17_9-6-20.png
Dateigröße: 290.48 KB
1.2m Prodelin 1224 az-el +
S: Helical feed, 0.8dB NF LNA
X: 1.2dB NF LNA, conical feed
12 Jun, 2020 21:51 50 s-band ist offline Beiträge von s-band suchen Nehmen Sie s-band in Ihre Freundesliste auf
secure-graphic.de Geblockte Angriffe: 305895 | prof. Blocks: 217055217055217113 | Spy-/Malware: 481
