Hi Satesco👋
Thanks for the advice, I set up Neumodvb. Another question. How to record a TS stream?
Brgds
Hi Satesco👋
Brgds
Hi all!
Please tell me what LNB C-band frequency settings are (which number is in which column) in the NeumoDVB program table.
Thank you in advance for your cooperation.
P.S. I just can’t figure out the size of the program data image in the terminal - the program table is much larger in width and height than the size of the terminal window.
Hi all!
I installed NeumoDVB, but the program does not detect the TBS6903x card, I think there is something with the drivers. Please advise what to do?
Hi Satesco👋
Thanks for the answer 🤝
Let me install Ubuntu for myself. Which version should I install?
And another question: Is it possible to record a BB-frame stream with NeumoDVB?
Brgds
Hi Satesco🤝
Could you help me install Neumo DVB on. Dragon OS with TBS6903X card?
Brgds
Alles anzeigen"aber keine Version von IQM funktioniert mit der TBS6903x"
Dem muss ich widersprechen
Ich habe heute einen Scan im K-Band auf 16°E gemacht, einmal mit der TBS6908 und einmal mit der TBS6903x.
Die 6903x hat mir nicht alle Transponder eingelesen, vorallem auch nicht 21563 mit der niedrigen Symbolrate (128 kS/s3).
Die Einstellungen waren bei beiden Karten ident.
Problem bei der 6903x ist der fehlende Scan. Man kann daher die RF Threshold nicht anpassen.
Ich habe es noch nicht probiert, aber Fensterpositionen in Windows lassen sich sperren.
Zwei Fenster bleiben es zwar, bleiben aber an der Stelle.
"but no version of IQM works with the TBS6903x"
I have to disagree with that
Today I did a scan in the K-band at 16°E, once with the TBS6908 and once with the TBS6903x.
The 6903x didn't read all transponders for me, especially not 21563 with the low symbol rate (128 kS/s3).
The settings were identical on both cards.
The problem with the 6903x is the missing scan. You cannot therefore adjust the RF threshold.
I haven't tried it yet, but window positions in Windows can be locked.
There are two windows, but they remain in place.
Thanks for showing the experience using the 6903x, I couldn't do that using IQM. And in Linux, I also still can’t mount Neumodvb (Cmake txt when installing, the text is red), which probably indicates some kind of error. P.S. Is it possible to record a GSE stream on Neumodvb?
Hello Femi!
I have tried all versions of IQM. They work with the (USB) TBS5580 card without problems, but no version of IQM works with the TBS6903x.
P.S. Another thing I don’t like about the program is that its working windows open and move separately.
Hi all!
The QMonitor program does not work for me with the TBS6903x. All Windows programs cannot work correctly with this card, which is why I switched to Linux. So far I have not solved the problem with installing Neumodvb.
Brgds
Ok
Thanks 🤝
Brgds
Thanks for the answer!
Dragon OS Focal R31 is a complete analogue of Ubuntu.
I think there is not much difference in installing NeumoDVB.
Brgds
Hi all!
Dear Satesco, could you help me install NeumoDVB? I have tried many times to compile this program, but nothing works.
P.S. Card TBS6903x v.2.
P.S.2 DragonOS Focal R31 system.
Thanks in advance for your answer.
Brgds
Hello! 👋
I'm new to Linux, so it's a little difficult for me to figure out how to install the NeumoDVB program. I have a question for dear users of this program: Is the program installed on the DragonOS X33 system? And is it possible to use this program to record a GSE stream using a TBS6903X card?
Thanks in advance for your answer!
Brgds
