Posts by flie
    inspired SaTom :70: by post here  :73:
    here my best signal in Ecowas 2 (Horizontal polarity) for more than 24H
    best signal between 03h30 to 19h00
    here my best signal in Ecowas 1 (Vertical polarity) for more than 24H it ,Ecowas-1 has a strange behavior here ! :25:
    best signal between 23h45 to 12h15
    seems that all Ecowas-1 transponders behave with the same way in my position :25: ,unfortunately I cant lock this transponder 12733,V,3500 best signal in early mornig 4.4dB but stil need 3.5dB :37:
    best signal between 23h15 to 10h30
    all data are stored in streamReader.log :73:
    12729,V,1700,34,2 ;4.9 dB :24 9/9/2023......................TS 42.5°E No-locked ! found with IQmonitor (SR=1750 *AhmedIraqi in flysat 2023/08/03)
    8=12732,V,3499,34,2 ;4.9 (-3.01) dB; 0:24 9/9/2023....................TS 42.5°E No-locked !
    I can't explain what happened ! but 02 Transponders locked to day :73:
    12727,V,1749,34,1 ;9.5 (4.04) dB; 12:37 10/9/2023
    12729,V,1699,34,2 ;3.5 (-0.53) dB; 12:37 10/9/2023
    12733,V,3499,34,2 ;4.1 (-3.81) dB; 12:37 10/9/2023....No-locked
    maybe because sun-outage is very close in this month ?! :25:
    ECOWAS1 in Vertical polarity
    Very hard to tell situation in vertical polarity since Turksat_4a south_beam activation :25:
    only 02 Unlocked TS- transponders :77: 12729,V,1700 & 12732,V,3499
    [SATTYPE]
    1=0425
    2=1.80m/IBU + C_feed
    [DVB]
    0=7
    1=12517,V,26250,23,3 ;7.1 (-2.17) dB; 0:24 9/9/2023...................Data 42.5°E
    2=12552,V,22500,23,2 ;6.4 (3.3) dB; 0:24 9/9/2023........................TS 42°E
    3=12587,V,22500,23,2 ;5.9 (2.8) dB; 0:24 9/9/2023........................TS 42°E
    4=12628,V,12500,23,2 ;5.3 (-1.32) dB; 0:24 9/9/2023.....................TS 42°E No-locked
    5=12657,V,22500,23,2 ;5.8 (-0.82) dB; 0:24 9/9/2023.....................TS 42°E No-locked
    6=12721,V,1199,34,2 ;11.3 (6.97) dB;0:24 9/9/2023.....................Data 42.5°E
    7=12729,V,1700,34,2 ;4.9 dB :24 9/9/2023......................TS 42.5°E No-locked ! found with IQmonitor (SR=1750 *AhmedIraqi in flysat 2023/08/03)
    9=12745,V...................................................9/9/2023......................Strong Carrier @ 42.5°E ?????
    *IQmonitor prameters : TBS5927 dF-super detailed HR spectrum Step=5000,signal search=2000,signal loop=jump loop=1000,SR=100-67500,IQn=1000X8,DVB-2X_mode :26. ,Old Streamreader 124133 used also with Crazyscan :73:
    For now -and at this moment- I can see traces from 12732,V,3500 only ! :37:
    Looking at my result to day I can see that my beam is ECOWAS2 in Horizontal polarity :73:
    [SATTYPE]
    1=0425
    2=1.80m/IBU +C_feed
    [DVB]
    0=5
    1=12517,H,29500,35,2 ;7.2 (1.7) dB; 21:11 8/9/2023
    2=12538,H,4999,34,2 ;7.8 (-0.11) dB; 21:11 8/9/2023 ...............locked at the limit !
    3=12545,H,6165,34,2 ;7.3 (-0.61) dB; 21:11 8/9/2023
    4=12554,H,8199,34,2 ;7.6 (3.57) dB; 21:11 8/9/2023
    5=12588,H,26250,34,2 ;8.4 (4.37) dB; 21:11 8/9/2023
    sadly for my first transponder reported in this thread " 12538 H 5000" was 8.2 dB with 0.90m....05 years go
    now it is 7.9 dB with 1.80m :37:
    12538H5000,3/4 8APSK Locked at the Limit of Link margin :94: and at this moment !!
    First time here with türksat-4a Africa south beam :3:
    thanks @ AhmedIraqi :70:
    [SATTYPE]
    1=0420
    2=1.80m/IBU
    [DVB]
    0=4
    1=12552,V,22500,2/3,QPSK2 ;8.6 (5.5) dB; 2:43 4/9/2023
    2=12587,V,22500,2/3,QPSK2 ;7.7 (4.6) dB; 2:43 4/9/2023
    3=12628,V,12500,2/3,8PSK ;9.4 (2.78) dB; 2:43 4/9/2023
    4=12657,V,22500,2/3,8PSK ;7.9 (1.28) dB; 2:43 4/9/2023
    here it is very close to NigComSat 1R Africa south beam @ 42.5°E
    Edit :/*after second look these channels in south beam are the same as in Ka-band in Turksat 4A same SR and with the same FEC !!
    I used the other BWEI LNB L. O.:12.8GHz (13.75-14.5)
    seems that my BWEI LNB 12.8GHZ is not working well !!! :77:
    KooLy what BWEI LNB do you have ?
    the plastic one -like me- or the metallic cover one ?
    sorry it is irrelevant question, but maybe not all BEWI LNB works !!! :25:
    According to this web site :
    Eutelsat's Hot Bird 13F and Hot Bird 13G satellites will begin commercial service at 13° East in two phases. The first will take place at the end of May 2023 , and the second is expected at the end of July 2023 .
    apparently same coverage map as previous Hotbird (B,C,E) satellite
