• DVBInspector 1.17.0 released
    DVB Inspector - Browse Files at SourceForge.net
    Note:
    To run this program it's nescessary to install a newer version of java JDK like 19.0.1 (latest)!
  • DVBInspector 1.18.0 released
    DVB Inspector
    Download DVB Inspector for free. DVB transport stream analyzer written in java. DVB Inspector is a java program to analyze captured DVB-streams. It is not a…
    sourceforge.net
    Note:
    To run this program it's nescessary to install a newer version of java JDK like 20.0.1 (latest)!
  • new java version released
    femi
    January 17, 2024 at 7:23 PM
  • Java jdk_22.0.1 and jre_8u411 released.
  • Java jdk_23.0.1 and jre_8u431 released.
  • :77: I forgot to say DVBInspector 1.19.0 released, now 1.19.2 ist the latest!
    Remember: Java 17 or higher is nescessary.
    With thanks to Eric Berendsen
    DVB Inspector
    sourceforge.net
  • Have anybody contact to Eric Berendsen, author of dvb inspector?
  • EricBerendsen - Overview
    Developer DVB Inspector. EricBerendsen has one repository available. Follow their code on GitHub.
    github.com
  • Java jdk_23.0.2 and jre_8u441 released.
  • Java jdk_24.0.1 and jre_8u451 released.
  • ... I forget the new version of dvb-inspector 1.20.0
    Release date: 21/04/2025
    This release requires Java 21 or newer!
    • added: show summary when root node is selected
    • changed: update to MJD processing to support 16 bit rollover in 2038. Thanks to Paul Higgs
    • added: description of component_descriptor value for T/UWA 005 (HDR Vivid). Thanks to Paul Higgs
    • fixed: CarouselIdentifierDescriptor, formatID is optional
    • fixed: AACDescriptor, aac_type_flag is optional
    • added: support for AVS3 audio and video. Thanks to Paul Higgs
    • added: HDR Vivid descriptor according to T/UWA 005-2.1. Thanks to Paul Higgs
    • changed: internal refactoring, a.o. KVP now extends DefaultMutableTreeNode so it can be used directly in getJTreeNode()
    Releases · EricBerendsen/dvbinspector
    DVB Inspector is an open-source DVB analyzer, written in java - EricBerendsen/dvbinspector
    github.com
  • New java versions released
    8.461 and development 24.0.2
    8.471 and development 25
  • Release 1.21.0
    Release date: 3/10/2025
    • fixed: first packet after discontinuity was not processed
    • added: export as .csv file to Bar Chart
    • added: export as .csv file to table views in detail panel
    • updated: versions of jfreechart and opencsv
    • changed: tooltip for temi always shows packetNo instead of time
    • added: use ctrl-c to copy tooltiptext in PCR/PTS/DTS view
    • added: support for TEMI data in PES packets
    • fixed: drawing TEMI timestamps
    • fixed: construction of AF Descriptors
    • added: M7 OTT_brandID_descriptor
    • added: support for ASTRA Service Guide Table (SGT)
    • fixed: show teletext data_unit_id=0x03 (subtitle) normal
    github.com
