New content at 3710L.
Megavision and Teleunion from Dominican Republic.
New: Loading HD
4161L 7500 S2/QPSK
Startimes packages are more weak as usual. On/under the lock limit with 2.4meter.
New content at 3710L package. LTV from Honduras.
Thanks duck77!
I'm interesting long time ago about USA C-band satellites, but no opportunity to receive here.
Replaced by CSS TV (test card) and Univers TV (black screen).
Sorry chucky, I`m in linear range at this time... can´t check 4090 L.
Okey, I checked, but on the limit with 1,75m. So active.
Complete scan.
New here - not sure about: regular service or feed ...?
4090 L 2400 4/5 DVB-S2 QPSK, CBS Reality Africa
Still active? I try with 1.75m.
Scan ...they changed again - not my catch, Zelda on LyngSat 14.02.21:
3698 H 4/5 DVB-S2 QPSK
Thanks! My signal with 1.75 meter.
Hi qwer,
How about signal level at 4160/4180R? I saw your report on FS. That's really circular ploarity?
Bei 12729H fehlt ca. 1dB, aber die übrigen MENA Transponder zwischen 12,5 und 12,75GHz auf H gehen gerade so
What time is the best to catch these freqs?
Morning, evening, daytime?
I try with 1.75m.
12466 V 41950 DVB-S2/8PSK , new fec 5/6 (was 3/4)
, lock at minimum here .
Still OK, with 120cm offset+Inverto BU here, but no any buffer.
Coming more near to that "contact" (11052 H)...
Try now qwer! Signal stronger than ever! 11062H weak now then usual.
My first catch from BADR 6 with 1.75meter.
12476V
11052H finally catch! Clear, stable picture with 175cm.
-8 celsius outside
New by fs: Signet package 3931L DVB-S QPSK (but S2-8PSK @fs)
Anyway, my situation with 1.8meter:
New, 4025R 1000 8PSK
Bnews 1 promo
/edit by qwer: merged in feeds atm. (probably regular service later?)
I'm back to C band after 3 weeks of KU.
Malaiaka & Boing still there?
I have no signal with 1.8m.
Just for my personal stats in this toppic...
11062 H 4500 1/2 DVB-S (ME beam) is back again here with 2.2m.
"smooth -10dB" at 11.45am. I´m quite sure the signal will increase the next hours.
/edit: signal check on last attached screenshots...
Very strange this beam. Normally signal increase late afternoon till 10pm. And then decrease. Some days almost same power around noon like 10pm. Some days nothing noon time...
Just my poor signal from this one (11165 H 45000 3/4 DVB-S2 QPSK).
This freq best signal between 8am 3pm CET. No signal in the evenings.
