1.2m Prodelin 2.5dB total system NF LHCP
12W WGS3
7600.000MHz 40dB SNR in 100Hz
28.2E Astra 2G (To be confirmed that it is not XTAR at 29E)
7676.000MHz 30dB SNR in 100Hz
12W WGS3
1.2m Channel Master with LHCP feed and ~2dB NF LNA
17.8W Skynet 5C 7340MHz LHCP (-150Hz offset)
30W XTAR-LANT 7493MHz LHCP (-330Hz offset)
At the signal levels received, I did not see modulation but it needs confirmation that they are actually CW and beacons.
Here's the TT&C on 7600.000MHz showing modulation. (2.4m PF)
The frequency read out is not quite correct. The beacon is within 300Hz of 7600.000
7600.000MHz with 1024kHz sidebands typical of WGS series
About 35dB SNR in 1kHz
1.2m Offset Dish
2 beacons specific to the DSCS SLEP series (Service Life Enhancement Program), I think. One at 7600.000MHz the other at 7604.705MHz. The latter frequency differs from the info here: https://www.globalsecurity.org/space/systems/dscs_3.htm
See also this post
The carriers are both about 18dB SNR in 1kHz on a 1.2m dish.
Thank you s-band for this reminder!
FYI: I added all reports from this toppic in X-band list now.
Skynet 4 C beacon
7331.5
Both nominally on 7600.000MHz but on this plot WGS-1 is in yellow and WGS-3 in green. Using the 8.4GHz RHCP feed so probably 10dB lower than usual (polarisation not determined at 7.5GHz). 1.2m dish.
Note the plot shows the carriers only. There is TT&C modulation on both signals.
1.2m Offset dish with 8.4GHz LNA/Feed, Polarisation not adjusted
7749.5MHz RHCP (TBC). Another plot showing ~28kHz shift since the previous (analyser locked to GPS).
1.2m Offset dish with 8.4GHz LNA/Feed, Polarisation not optimised
7250.518MHz LHCP
Waterfall added: 21.4MHz = 7250.518MHz
I'm assuming that this is a beacon on 7662.5MHz RHCP. The polarisation needs to be confirmed.
21.4MHz = 7662.5MHz
Edit 11/10/23 - See this post for an analysis
7662.5MHz LHCP & RHCP
This is a strange one. In the earlier post I was confused about the polarisation. I re-installed the system and whilst optimising polarisation noticed that there are both LH & RH signals present. The RH appears to be much stronger than the LH. The X polarisation rejection seems to be better for RH than LH but that needs to be re-checked.
The LH beacon was about 180Hz low of 7662.5MHz and the RH about 150Hz high.
1.2m dish, 1dB NF LNA, 9GHz LO, Airspy R2 on RPi, SDR++ on Linux
